350z vs g35 suspension
Old Mar 23, 2010 | 05:14 PM
socialconflicts's Avatar
ima be putting some coupe 18s on my car, i have read the g35 coupe suspension gives a 1/2 drop vs the 350z which gives a 1ich drop. i really dont wish to roll my fenders and was concerned that if i go with the 350z suspension it will hit my fender. what do you guys think?
Old Mar 23, 2010 | 05:44 PM
Tollboothwilley's Avatar
No, you won't hit your fenders. Plenty of people have rocked that for a while. of course, this largely depends on the offset of the rims you choose. for an 8.5 or 9" wheel in the rear you won't have an issue assuming your offset is between +27 and +40. You should keep it around +30 or a little smaller if possible. take a look at all the threads about the 350z suspension, including the STICKY in the Brake & Suspension forum.
Old Mar 23, 2010 | 08:12 PM
NFSP G35's Avatar
? = 2B || !2B
^+1. I'm running Z suspension with stock 17's no problem and I know some members are running 245 width tires on 19x8 +30 with no problems.
Old Mar 23, 2010 | 10:55 PM
lox1985's Avatar
I'm rocking 350z with 19x8 +45 and no rubbing here. I'm going to run some spacers soon as well, should not need to roll fenders.
Old Mar 23, 2010 | 10:57 PM
lox1985's Avatar
^^ oh and I'm running 245/35 everywhere but I could go up to 40 no problem
Old Mar 24, 2010 | 02:11 AM
BuckeyeInMI's Avatar
The OP said Coupe 18's, not 19's. They're 18x8 with a +30 offset. It's a great fit on this car, and shouldn't rub with a Z spring drop, but you should measure before you drop to see if you need to roll your fenders.
Old Mar 24, 2010 | 02:15 AM
kennymo's Avatar
i have some front z springs for sale if you need some.
Old Mar 24, 2010 | 02:37 AM
well i do essentially need the springs, im looking for a a whole suspension... since zsprings wont match the G suspension
Old Mar 24, 2010 | 08:31 AM
NFSP G35's Avatar
? = 2B || !2B
Just so you know, it is POSSIBLE to do springs only. But it will wear out the shocks faster. It's not as bad if you have the sport suspension (red shocks)
But you best bet is still to do the whole suspension liike you said.
Old Mar 24, 2010 | 02:40 PM
kennymo's Avatar
yea what he said
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
