I just pulled the Infiniti letters off with my fingers, then the G35 was thick enough to carefully grab with a pair of side cutters then rolled the adhesive off
One more
you can get 3M adhesive remover at most auto part stores in the paint section. It also works wonders on stains on your interior cloth, it evaporates dirt. But any bug and tar remover will do. Personally I use blazing hot water and car wash came off like butta
dofu
close
- Join DateSep 2005
- LocationSilicon Valley
iTrader Positive Feedback100
iTrader Feedback Score(9)
Liked:242 Times in 197 Posts
Use some dental floss or fishing line to saw through a bit of the glue, as close to the paint as possible, then rip the emblem off and saw where needed.
Once you have the emblem off, use Goo Gone to soften the rest of the glue. Use an old library card or expired credit card to scrape off most of the remaining glue - Do not use your finger nails!
Use a rag and Goo Gone to get rid of the remaining residue.
Wash the car! At least where you applied Goo Gone.
Adhesive remover is a better option though...
NFSP G35
? = 2B || !2B
close
- Join DateApr 2009
- LocationTallahassee, FL (or thereabout)
iTrader Feedback Score(22)
Liked:852 Times in 640 Posts
Quote:
http://www.youtube.com/watch?v=3ifYIRTL8aw
Dude, you were scaring me with those cutters Originally Posted by Longduckdong
I just pulled the Infiniti letters off with my fingers, then the G35 was thick enough to carefully grab with a pair of side cutters then rolled the adhesive offhttp://www.youtube.com/watch?v=3ifYIRTL8aw
I just did this last week, if you dont have a heat gun, just make sure the sun is hitting the trunk for a while.
i started around noon and it was maybe 70-75 degrees outside. Used fishing line to saw the letters off, then soaked the adhesive with goo gone waited about 5 minutes and used a credit card to scrape some of the adhesive off, then repeated. ( an no the credit card didnt scratch the paint)
worked fine for me, just took some time, and patients
Quote:
Use a paint scraper with microfiber towel wrapped around it.
this is what i used because for one car was not being hit by the sun lolOriginally Posted by FRY TWO
Tip #384568:Use a paint scraper with microfiber towel wrapped around it.
but i got most of it off and tomorrow i will try the goo gone to remove the extras, do you guys think its safe if the surface is hot and i put goo gone?
Quote:
"The long term active ingredient is a non-volatile, viscous oil which remains on the surface, providing lubrication"
Quoted from here:
http://en.wikipedia.org/wiki/WD-40
not talking crap, just informing
lol no worries "penetrates stuck parts, displaces moisture, and lubricates just about anything" we are both right got that from wd40.comOriginally Posted by OCG35
It's function is used as a lubricant:"The long term active ingredient is a non-volatile, viscous oil which remains on the surface, providing lubrication"
Quoted from here:
the thread went from debadging to the properties and uses of WD-40! love it
Quote:
http://www.youtube.com/watch?v=idXksPEOqfk
not lately... it's been real hard to find here (I need a new can of it)...Originally Posted by Longduckdong
One more http://www.youtube.com/watch?v=idXksPEOqfk
