rear camber
Old Apr 16, 2010 | 06:11 PM
  #46
SN00P's Avatar
CLUB MODERATOR
im going to be in the -2.1* and spec in with the Z's im not the far off either i mean if i can get close to that i will defiantly be happy
Old Apr 16, 2010 | 07:55 PM
  #47
CG4DR's Avatar
michelin pilots stretch really nice look amazing too..
Old Apr 16, 2010 | 08:13 PM
  #48
SN00P's Avatar
CLUB MODERATOR
im thinking the only way i can get my camber perfect and within spec is do i nice mild stretch ...
Old Apr 17, 2010 | 01:08 AM
  #49
The Stimulation's Avatar
Man, I wish I could at least be at -6 camber. I think I'm gonna say f*ck it and dial in some positive camber and deal with tire rubbing. F*ck the damn cops for givin me sh*t when I rub only goin up driveways. At least my wheels won't scrape and I can lower my car more.
Old Apr 17, 2010 | 02:04 AM
  #50
Mr.G35 Steven's Avatar
no matter what drop u have u will still have a neg on ur car from be lower i have tanabe df210 im -1.7 in the front and rear -2.8 no camber kit front i have camber kit before was -2.8 sumthing like that it was bad tho
Old Apr 17, 2010 | 09:09 AM
  #51
SN00P's Avatar
CLUB MODERATOR
^^ yea I'm close to -3.0* an with a camber kit I'm lucky to get to -2.5* cause I'm just so close to my fenders but hey i got the toe and caster dead on so right now I'm happy with that
Old Apr 30, 2010 | 02:19 PM
  #52
saoLin413's Avatar
I'm on tein basics with SPC Camber kits all around and have the car dropped enough that the tires are slightly tucked into the fender. Camber is 2.8 all around. If I take out the front camber kit and put the stock ones back on can anyone guesstimate what the camber will be at??? Thinking of taking the front one out because it knocks when I hit a significant bump while riding this low.
Old Apr 30, 2010 | 03:22 PM
  #53
SN00P's Avatar
CLUB MODERATOR
i have stock camber arms in the font of my car I'm at -3º rear and my fronts are -1.8º and I'm dropped 2.5'' all around
Old Apr 30, 2010 | 03:37 PM
  #54
saoLin413's Avatar
Cool so they were able to get your caster and toe up front back into spec with the stock arms???
Old Apr 30, 2010 | 04:11 PM
  #55
SN00P's Avatar
CLUB MODERATOR
yes correct ... my toe and caster with stock arms and rear link are in spec the only thing is my camber is off
Old Apr 30, 2010 | 04:15 PM
  #56
saoLin413's Avatar
Cool, I may take off my spc front camber kit then get alignment again. I can't stand the knocking. Guesstimating the stock arms would put me around -2.4 maybe if you're at -1.8. Thanks for the info!
Old Apr 30, 2010 | 04:28 PM
  #57
SN00P's Avatar
CLUB MODERATOR
what do you mean put you around -2.4º ?? before i went to get an alignment done my car was at F- -2.1º front and R one side was -3.6º and the other was -3º and after my alignment im not at F- -1.8º and my rears are at -3º ...
Old Apr 30, 2010 | 04:34 PM
  #58
saoLin413's Avatar
You have a 2.5 drop all around and they got your camber to 1.8 with the stock arms after alignment right? I'm riding much lower than 2.5 inches so i'm just assuming they can get me around 2.4 if I put the stock arms back on. I been debating about taking off the SPC front camber for some time due to the knocking issue. Just wanted to make sure that my camber will not get worse than the 2.8 i'm at right now if I go back to the stock arms.
Old Apr 30, 2010 | 04:55 PM
  #59
SN00P's Avatar
CLUB MODERATOR
ooo ok i got you yea my fronts are right around -2º nothing more so yea you should be around -2.5 my guess ... i kinda like the negative camber .. as long as my toe and caster are fine i have no problems with the camber ... i think you should be fine
Old Apr 30, 2010 | 05:01 PM
  #60
saoLin413's Avatar
Yeah man thanks for the info. I'm going to take off the SPC up front for sure now. I thought I needed it in front to get the caster and toe in spec but if I don't then it's pretty much useless at the height I like riding at.
