Subwoofer on stock stereo
Old Apr 20, 2010 | 10:49 PM
alexh521's Avatar
my freind just offered me his 12in and i was wondering wood it even sound good on a stock BOSE stereo?
Old Apr 20, 2010 | 11:07 PM
oscar_g-sedan06's Avatar
depends what kinda bt a lot of people have add subs etc. to there stock bose stereo...i have ran 2 12'' on the stock bose stereo sound good no problems
Old Apr 21, 2010 | 01:01 AM
NFSP G35's Avatar
? = 2B || !2B
Wrong section.
Old Apr 21, 2010 | 08:26 AM
blazeplacid's Avatar
get a line out put converter (LOC) it will only send the lower frequencies to your sub/amp.
I dont know how low of a signal the stock head unit puts out but im sure its low enough to notice a sub in the back.
Old Apr 21, 2010 | 11:57 AM
B T's Avatar
B T
Depends on the kind of music you play and what your looking at. I used to run 2 12"s but they overpowered the mids and highs too much. Also had to run a remote gain **** to the cabin just to be able to get decent sound out of it between different bands. Always required constant tweaking. I switched to a high power 10" and have never been happier with the sound of my car. Make sure to turn off or lower your SSV setting to minimize variations while driving, it has a noticeable impact on subwoofer level compared to mids and highs.
Old Apr 21, 2010 | 03:17 PM
awong's Avatar
I'm running 1 10" and it slap hard. ANd also depends what sub you got, amps, and the design of the box
Old Apr 21, 2010 | 08:51 PM
alexh521's Avatar
its a pyle 12in self amplified 800 watt. Ive heard that it would j be easy to splice the woofer in my rear deck to add this one in...would that work ok?
Old Apr 21, 2010 | 09:30 PM
those are easy to install
just run a power wire from your battery and a ground to a chassis ground
it should turn on with a signal from the factory speaker wires
pyle isnt the greatest brand, but if you allready have it, go for it
Old Apr 21, 2010 | 10:35 PM
alexh521's Avatar
lol i actually startedlooking around and i found a powered 12in sony xplode 1000watt ...would that install the same way?
Old Apr 21, 2010 | 10:51 PM
NFSP G35's Avatar
? = 2B || !2B
^Those suck.
Old Apr 21, 2010 | 11:26 PM
03GT35R's Avatar
Running RF 2-10" P2's with RF Punch 500 on Subs & RF Punch 300 on mids/highs all on the Non-Bose Stock head unit, all is fine except the CRAPPY stock 6-disc Changer. Its not working again...imagine that...Time for an upgrade..
Old Apr 21, 2010 | 11:27 PM
NFSP G35's Avatar
? = 2B || !2B
^No those subs do NOT suck!
Are those in the RF box? If so, my cousin had that setup
Old Apr 22, 2010 | 12:04 AM
ThaDiesel86's Avatar
Sony Explode don’t suck. I had many subwoofers, Sony Explode(SE), Rockford Fosgates(RF) and Audiobahns, all have their pros and cons. It all depends on the music you listen to. SE and Audiobahn speakers work really well with rap, hip hop and pop and music with a lot of bass line. Audiobahn sucks because they blow to easy. And the only time that SE speakers suck is when they are not ported. Rockfords Fosgates are amazing, but they are only amazing with rock music or music with lot of bass hits (no bass line) and not ported. RF suck with bass line. So it is your choice.
Old Apr 22, 2010 | 12:23 AM
NFSP G35's Avatar
? = 2B || !2B
^IDK dude. I listened to a SE and a RF in the same box, same amp. The Sony was completely shamed by the RF. It had cone flex like CRAZY. And I'm not talking about rock (you're right though, the RF's do like rock) I'm talking hip hop bass.
Old Apr 22, 2010 | 09:45 AM
geew1z's Avatar
To convert the differential outputs from the bose HU, is this whats needed?
http://www.crutchfield.com/p_127OEM2...2.html?tp=3486
