Have to replace my engine, couple questions.
Old May 1, 2010 | 04:00 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by G35fromTO
So how did that happen?
^V-Tec kicked in..........
...........yo.
Old May 1, 2010 | 04:14 PM
DaveB's Avatar
Originally Posted by AceG35X
Although its not a frequent/common problem... since he's gonna have the engine out and its high mileage i would change it...
I wouldn't. Just because it might be easy to do because the engine out, it's not a high failure part. It would be like saying, replace the rings because it's easier to do since the motor is out. Secondly, replacing the chain isn't a terribly easy process. And finally, if you're going to do it the right way, you should replace the tensioner, slack guide, chain guide, and tension guide. When it's all said and done, you're out about $300 to $450 depending on where you get your parts.
Old May 1, 2010 | 04:16 PM
NFSP G35's Avatar
? = 2B || !2B
^I wouldn't worry about the chain either. I've never heard of one breaking.
Old May 1, 2010 | 09:45 PM
dsmbill's Avatar
Well i will never no for sure why it happened, but i assume it is cause of the oil consumption problem. When i got the car i didnt know about it and the first couple oil changes the places i went to never mentioned it was short on oil. Well when i moved and took it to a new place in ny they said no where near enough oil cam out. that is when i started to research about it and joined this site. well once finding out about it i tryed to keep up on it but i believe the damage was already done.
Old May 1, 2010 | 10:54 PM
Tollboothwilley's Avatar
Originally Posted by 4D05G35
Cheap insurance! I would probably change the chain too,its easy and that much longer you have to go till you run into problems.
Chains do stretch as you know.
what were the symtoms that the o-ring going out on the pump caused? leaking fluid everywhere?
Old May 2, 2010 | 12:38 AM
DaveB's Avatar
The coolant starts to slowly weep out of the water pump cover.
Old May 2, 2010 | 01:40 AM
BuckeyeInMI's Avatar
...........yo.
Hasanbaloch
Feb 29, 2024 08:45 PM
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
itschuckster
Jul 25, 2015 08:07 AM
apintojr
Jul 23, 2015 10:52 AM
