Acceleration Clicking Noise
Old May 3, 2010 | 11:38 PM
Jimmy4645's Avatar
Wondering if you can diagnose my problem because the local dealership has no idea.. For a while now, during acceleration i have been hearing a clicking noise.. The clicking noise is intermittent.. Any ideas what is causing the noise.. thanks
Old May 4, 2010 | 12:30 AM
codeflux's Avatar
at what speed? how loud is the clicking? once click or many? from what side of the car?
Old May 4, 2010 | 12:47 AM
Jimmy4645's Avatar
0-35mph i notice it. 15-25 mph i notice it too
couple seconds of multiple clicks and disappears either by me removing my foot from the gas pedal or it just stops in the middle of acceleration
The clicks are intermittent.. I do not hear it every time i accelerate. I once noticed it when the car was parked and i was reving the engine, but the clicking noise were short, but mostly hear when I'm driving it.
I hear the clicking noise out of my drivers side window predominantly when I'm passing a high curb or wall when the clicking noise bounces out from under the car.
Old May 4, 2010 | 01:56 AM
AARONHL's Avatar
Wheel bearingggggggggg
Old May 4, 2010 | 01:58 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
it's not a wheel bearing if he heard the noise while the car was parked.
Old May 4, 2010 | 09:19 AM
CLyons0203's Avatar
axle click, common problem on G35s. not covered under ellite extended warranty. Remove axles, grease hubs, fixed.
Old May 4, 2010 | 09:50 AM
SiouxFallsG35's Avatar
Does this happen at all air temps? If it doesn't happen when colder, and it's more along the lines of a ticking, then it could be engine ping. Typically with hotter air temps, you might hear this under medium to heavy acceleration and generally around 2-4k RPM with the VQ.
Old May 4, 2010 | 10:47 AM
DaveB's Avatar
Bingo.
My 03 does it intermittently just like it does with the compression rods. Chances are, the noises will go away for a few months, reappear for a week, and then go away again. It's not a problem. Just a minor annoyance.
The clicks while revving the motor at a stop are most likely the fuel injectors. They're noisy.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
