Exhaust Confusion- I searched
Old May 6, 2010 | 07:57 AM
  #61
SedanManBen's Avatar
Originally Posted by jaswrx
SO the HR Y-pipe has to be taken on a 350z or G37?
None of the G35 Coupes came with HR Ymidpipe? Or wait, they all do but it is the wrong size... do I have this finally right?
HR stands for "HIGH REVOLUTION" aka the cars with the REV-UP motor.
Normal G35s have the VQ35DE motor.
Those with revup (and newer model 350z) have the VQ35HR
That's where the HR comes from.
The HR y-pipe from the G37 isn't the same from my experience on the forums... it's slightly smaller diameter in some areas (can't remember).... and I'm not sure about this one.. so someone correct me if I'm wrong.. but just because a G coupe has the "rev up" motor... doensn't mean it has the HR y-pipe.. I think they refined it at a certain year
Old May 6, 2010 | 03:41 PM
  #62
jaswrx's Avatar
ok. so my buddy that has a 06G35 Rev Up does or does not have a HR Ypipe?
Old May 6, 2010 | 03:47 PM
  #63
OEM is on left, HR is on right. It's amazing what google can do for you. lol this even came from a G35driver thread.....
IMHO... an HR y-pipe is harder to find than just an aftermarket.... I mean.. I have a nismo and I'm only askin' $150 for it
Old May 6, 2010 | 03:55 PM
  #64
jaswrx's Avatar
i see the difference. I get that but what I am trying to make sure since know one has truly clarified is... do previous year 03-8 G35 coupes THAT HAVE "Revup" HR Y-pipes direcly bolt onto 03/04 and 05/06 G35 RWD Sedans?
I also realize that it may be very hard to find them... so I was looking at the stilled, and would order the one for the 350z, correct, not the Coupe?
Old May 6, 2010 | 04:05 PM
  #65
I'd be lying if I could specify if G coupes with revup even had them to be honest? I'm not sure on which models/years had them...
Just know this much.... Y-pipes are the exact same on the sedans, coupes, and the 350z. The X sedan is the only one that has troubles with some y-pipes
Old May 6, 2010 | 06:38 PM
  #66
CG4DR's Avatar
ok so since i have a 05 revup sedan why do i have the one on the left?
Old May 6, 2010 | 06:41 PM
  #67
SN00P's Avatar
CLUB MODERATOR
Originally Posted by g35snoop
its going to give you a better sound like the coupes .. but you need the HR Y pipe
the one on the left is a sedan pipe and the right one is the HR Y pipe so you no the difference
i had posted this pic up on the 2nd page
do people not search the web anymore ??
  #68
CandlestickPark's Avatar
ill Sedan
Yes you have the one pictured on the left.
Old May 6, 2010 | 06:48 PM
  #69
CG4DR's Avatar
well someone said hr is THE revup motor and the one on the right is revup lol
Old May 6, 2010 | 06:55 PM
  #70
OCG35's Avatar
quick correction... the RevUp is still a DE (slightly different lower plenum and different oil pump, rods/bolts, probably a few other minor changes, but still a DE)...
the HR is an entirely different engine.
Old May 6, 2010 | 06:58 PM
  #71
OCG35's Avatar
its corrected above... HR is not RevUp.
Old May 6, 2010 | 07:00 PM
  #72
jaswrx's Avatar
^^ now more confused... what cars are the HR engine in?
So there is a VQ35DE and VQ35DE Revup, WHICH IS NOT HR THOUGH
Old May 6, 2010 | 07:09 PM
  #73
Jeff92se's Avatar
Red Card Crew
Basicly any G or Z from 2007 on up. It will be powered by either the HR35 or the HR37 motor. Both will have the same HR Y pipe you can use.
But the HR powered Z from 2007+ is probably the one to get. It's probably splitting hairs but it look like it's not slightly pinched down at the cats
Old May 6, 2010 | 07:13 PM
  #74
OCG35's Avatar
in the sedan, 07 and newer
yes
Old May 6, 2010 | 07:17 PM
  #75
jaswrx's Avatar
Got it!
Thanks!!!
