Change radiator hoses
Old May 19, 2010 | 02:24 PM
KingoftheRoad1's Avatar
I have got about 80K and summer is around the corner. I plan to change the 2 radiator hoses before they go burst on me. The top one looks easy enough to change without losing coolant. My question is the bottom hose. How do you change the bottom hose without losing the coolant? My coolant is new so I don't plan to lose it. Many thanks in advance
Old May 19, 2010 | 02:26 PM
istan's Avatar
Can't avoid losing coolant when changing the lower hose.
Old May 19, 2010 | 02:37 PM
blazeplacid's Avatar
when changing the lower hose you will lost some
antifreeze is like $10...
K Dub's Avatar
No way you are going to change both hoses without losing coolant and rebleeding the system.
Old May 19, 2010 | 03:53 PM
Mustang5L5's Avatar
Replacing the lower hose without losing coolant is like changing your oil plug gasket without losing oil.
Just do both with a coolant flush
Old May 19, 2010 | 03:59 PM
Blue Dream's Avatar
I drove ttrank's car solo
Or catch the clean coolant in a pan when you pull the hoses and put it back in the radiator when you're done??
Seems like a simple, easy answer.
Old May 19, 2010 | 04:05 PM
istan's Avatar
Yes. Only issue is going to be rebleeding this nightmare of a coolant system.
Old May 19, 2010 | 07:19 PM
ZE120's Avatar
bleeding the coolant is not that bad....
it was easy for me
Old May 19, 2010 | 07:54 PM
istan's Avatar
lucky. I'm like 2 year into bleeding my coolant and it still isn't fixed :haha:
Old May 19, 2010 | 08:35 PM
AARONHL's Avatar
I feel your frustration!!
Old May 19, 2010 | 09:28 PM
NFSP G35's Avatar
? = 2B || !2B
You guys aren't helping me...
I'm due for a flush and I'm already scared of bleeding this thing
Tukeeg35
Cooling
Oct 20, 2016 04:14 PM
NohoG35revup
Aug 22, 2015 12:13 PM
pigpen infiniti
Aug 16, 2015 09:07 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
