coilovers
Old May 25, 2010 | 03:19 PM
xxxxxxxxxx's Avatar
coilovers
is there any way to adjust the damper on the coilovers without taking them off , like can you do it by the inside of the car. and im talking about the rear ones
Old May 25, 2010 | 03:37 PM
The Stimulation's Avatar
Depends on the coilovers you have. If you have ones like the Impul Ohlins and the HKS Hypermax III's then you stick your hand between your wheels (if spokes are wide enough) and adjust through there.
Otherwise you have to get extenders. Not sure how it works with all sedans, but I have reclining rear seats so I can bring the seat forward, take off this flap, and adjust through there.
Old May 25, 2010 | 03:47 PM
xxxxxxxxxx's Avatar
i got bc br coilovers . i was trying to take out the back seats but it look like it was going to be a mission to do that
Old May 25, 2010 | 03:55 PM
CandlestickPark's Avatar
ill Sedan
^BC Racing coils have extenders. You can purchase them for like $35 IIRC. I have BC Coils, never installed the extenders, but it only takes like 10 mins to remove the back seats and adjust the dampening.
To remove the back seats:
1. Pull the back tab out at the base of the seat on each side and life the bottom portion of the seat up. Back the seat belts through the openings and set the bottom part of the seat aside.
2. Remove the 2 14mm nuts on both sides (4 nuts in total) that are securing a metal "hook" at the bottom of the back part of the seat.
3. Pull bottom of the seat back out towards you.
4. Push seat back up then out towards you.
5. The top of the shock tower is now visible and you can adjust the dampening.
6. Do everything in reverse order to put it back together. Make sure you pull the black tabs all the way out then push the base of the seat down, hard to remove again if its not installed properly.
Old May 25, 2010 | 03:57 PM
Bestswat's Avatar
I have the extenders, they make life so much easier. Takes a total of 5 seconds.
Old May 25, 2010 | 11:04 PM
FlyingLumpia's Avatar
unless you have the premium package and your seat recline.
Old May 25, 2010 | 11:13 PM
350GT-R's Avatar
so if your rear seat recline you have the premium package? is that good or bad?
how many packages are there?!!
Old May 25, 2010 | 11:17 PM
Sports, aero, and premium.
I don't see why having the premium package would be bad. Reclining seats are awesome. It feels like you get more leg room.
Old May 26, 2010 | 01:18 AM
350GT-R's Avatar
what kind of package is the awd one?
Old May 26, 2010 | 11:43 AM
None. I think that would be another package or just another drive-train option.
Old May 26, 2010 | 12:21 PM
xxxxxxxxxx's Avatar
naw my seats dont recline
Old May 26, 2010 | 01:08 PM
No premium package then
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
