so your abs light is on your car? i umplugged batery but still problem continues, i took to mechanic hes telling me its actuator. i called dealer they quoted 1400 for that part
Actuator price is definitely in that range.
I had the same problem a few weeks back. Had a mechanic friend who has a basic diagnostic tool... plugged it in under the steering wheel and it showed a code which I looked up online. Front right speed sensor was gone. Replace with labour for $300. Problem solved.
TunerMax
close
- Join DateDec 2011
iTrader Positive Feedback100
iTrader Feedback Score(3)
- My RideG35
Liked:359 Times in 258 Posts
This is actually pretty easy to check on the front wheels without any tester. Turn the wheel to the stop so you can check, jack it up, and shine a light at the abs sensor. if you see lots of debris or damage between the ring and the sensor, then you know which sensor it is.
Comparing all sensors will give you a pretty good idea of where the problem is. Obviously, it's far from fool proof, but it'll cost you nothing but your time
Mine was just fixed , with the computer being reset. He sai sensors are good, had te actuator burned out. I was looking at 1500+
Quote:
Originally Posted by theyog
I had this exact problem a couple months back. It is indeed a problem with the ABS system. My mechanic reset the system and the lights and noise have not been back.
Anyone know how to reset the system???
Quote:
You need to hook it up to one of those portable computers with the codes on them (I'm forgetting the name of this thing). My mechanic did it for free.Originally Posted by teahead
I still don't understand why people try to guess what is wrong with their cars. Pull the error codes from the ECU and you will know..
Randomly guessing isn't going to work most of the time.
Pull the code and you will know where to start fixing it.
BTW, I had the same problem a few weeks ago.
+1. Most local auto parts stores like Autozone, Pepboys, etc. will check the codes for you with a OBDII scanner and can clear them for FREE.
I tried the pulling codes no codes. My ABS keeps running with the car off, I went to advance auto parts and its not throwing any codes the vdc off, slip, abs lights are all on. Does anyone know how to reset it? btw taking the negative batteryterminal off for 20 minutes does not clear it i dont think.
Quote:
You may need a more adv. code reader.Originally Posted by lonatic
something like the autoenginuity reader with the extra enhanced nissan codes package.
This is what I have .....
I fixed it, I took it to advance and had it read by a reader that reads abs codes still nothing. He suggested i try LIGHTLY tapping the sensors by the abs and the abs with screw driver... well what do you know.. it worked like a charm.Originally Posted by si_driver
You may need a more adv. code reader.something like the autoenginuity reader with the extra enhanced nissan codes package.
OK looks like I will ahve to join the ABS problem club.
Car starts and runs great, but it seems that ABS light comes on and stays on when i drive in some rough, or not very smooth surfaces...bumps on the roads and all. When the light is ON, sometimes even slight breaking seems to engage the ABS to kick in (you know, that feeling of abs pumping breaks) I am lowered. Oh and once I turn the car off, it goes away. Break fluid is willed between empty and full.
Ran a diagnostic couple of month ago, but back then didn't have a problem...should i give it a shot again?
Quote:
If this lights turning on in a bad road, or in acceleration - it's only breakin fluid level.Originally Posted by muhtish
It must be a FULL, or some higher in 1-2 mm.
