Carpet
Old Jun 26, 2010 | 04:49 PM
toymachine2009's Avatar
Carpet
In the back of my car the carpet is bubbling or peeling up or something looks super deformed right in front of the back seat? anyone had this issue or know what to do. Ill go try to get some good pics of this.. Its really bad..
Not sure if its from the extreme heat or what? Its by the corner of the seat on the passenger side
Old Jun 26, 2010 | 08:00 PM
Wannabe6MT's Avatar
-MN G Crew-
Check under your car. Have you had it lifted up recently for service or anything? I had this on my drivers side floor and upon further inspection, found that the floor had been pushed up. 10 mins with a hammer and the floor and seat pulled up, i had it all pounded back down to normal.
Old Jun 26, 2010 | 09:17 PM
BINGO! I jacked up my car to paint my wheels! thats what it is. So how do i fix this issue? just take a hammer and hammer out the floor.
Old Jun 26, 2010 | 09:55 PM
Tangerine's Avatar
I've jacked up my car many times and had no similar issue. I would be more worried if my carpet was like that just because of jacking up the car. Did you use the correct jack points?
Old Jun 26, 2010 | 10:01 PM
Wannabe6MT's Avatar
-MN G Crew-
^No, he didnt.
OP your going to have to peel back the carpet, remove the foam piece under neath and pound down the actual metal.
Old Jun 26, 2010 | 10:14 PM
dsmmyth's Avatar
Ouch.
Yeah, make sure you use the correct jack points or jack up on the chassis. :x
Old Jun 26, 2010 | 10:25 PM
where are the correct jack points? I just do whatever feels sturdy and if it doesnt cave in I go with it.. apparently it caved in lol
Old Jun 26, 2010 | 10:27 PM
Originally Posted by Wannabe6MT
^No, he didnt.
you make it sound easy.. lol isnt the carpet it attatched to the floor somehow?
Old Jun 27, 2010 | 12:24 AM
Wannabe6MT's Avatar
-MN G Crew-
Yea kinda, just peel it.
Old Jun 27, 2010 | 01:12 AM
and how do you put it back?
Old Jun 27, 2010 | 01:29 AM
thescreensavers's Avatar
Mr.202?
The whole carpet is attached on the sides you need to remove all the rubber and plastic trim on the door, also you need to remove the back seat,( just look right in front of the left and right passenger there is a tab you just pull it out and pull up on the seat) Then you should have access to that side.
Thats very scary lol, were did you jack up the car at man lol
Old Jun 27, 2010 | 01:41 AM
Well I guess right there where the carpet is coming up lol.
Old Jun 27, 2010 | 01:52 AM
Wannabe6MT's Avatar
-MN G Crew-
Make sure from now on that you jack it up on the jack points (its right under the door, looks like wavy steel with some divots in it.)
Old Jun 27, 2010 | 02:26 PM
TurTLe*'s Avatar
he did it at the floor board... he didn't want to go lift at the pinch weld because it was just a thin line, instead he went for the nice flat spot about 6 inchs further in...
if you have to lift the rear.... MOST times if you can just lift the rear DIFF up...
Old Jun 27, 2010 | 04:49 PM
I agree with what he said bout where I lifted it and why?
