PSA: Powersteering Fluid
Old Nov 1, 2010 | 07:08 PM
  #61
WhosRich's Avatar
Originally Posted by OKStateG35
I did a full drain/flush on mine and it really isn't difficult. Obviously not as easy as the turkey baster method, but still really easy.
In the DIY video, it looks like 2 people are needed to disconnect the hose. That is pretty difficult since you cant do it by yourself.
Old Nov 1, 2010 | 10:54 PM
  #62
thescreensavers's Avatar
Mr.202?
Originally Posted by TurTLe*
all you guys posting about this "smoother" feeling i really have to do this because i'm pretty sure its a placebo effect, like a lot of things are not.
I did it on my GF lancer, she didn't comment on it at all. Now she might not be the most sensitive person in the world in terms of driving but the way everyone talks about it, it would make sense she would notice it feel a lot better after 60k.
Mine got legitimately lighter. After 2 changes of fluid it got lighter. Then the 3rd it got a bit more lighter. Then the fourth I felt no more benefit.
On my friends car Mazda 6 and my Dads LS which both were black. We did the fluid change and felt no difference.
So It must just be how the G is set up. My Bro also commented how it felt lighter. He just moves my car rarely so people can get out of the driveway..ect
Old Nov 1, 2010 | 11:06 PM
  #63
Mustang5L5's Avatar
Didn't notice jack when I did mine....but I've always done it frequently.
You guys are overanalyzing this a tad. Just buy a bottle of ATF, suck the old **** out, pour some new **** in, drive it around a bit to mix the **** around and then do it again til you are out of **** and call it a day.
Old Nov 2, 2010 | 09:14 AM
  #64
OKStateG35's Avatar
Mine wasn't difficult at all. Just twisted it back and forth and it pulled right off. I took my wheel off for easier access. You can hold the metal part with your other hand if you are worried about bending it.
Also, like I said, I did notice a difference in the steering afterwards. Not a lot, but it was smoother. Maybe Turtle's GF pays attention to her car more, but my wife would never notice something like that.
Old Nov 3, 2010 | 02:23 PM
  #65
g35newbie3's Avatar
Originally Posted by thescreensavers
You are just sucking out the reservoir its not that big and yes I sucked it all out, I believe the whole system holds 1.5 quarts.
Yea, just fill it back up to max cold level and then just repeat a day after driving or what not. The Reservoir has a Air pocket already, its just a tank that holds extra fluid for the system.
Make sure to look at the opening for reservoir, its hard to find a turkey baster that fits lol.
Doing this tonight when I get off work since I finally have time. Did you use a turkey baster? Or something else to suck the fluid out.
I will let you all know how it goes!
Old Nov 3, 2010 | 04:51 PM
  #66
Mr.202?
What ever you can get into the bottle to the bottom will work. I just use a Syringe with a tube attached to it.
Old Nov 3, 2010 | 10:17 PM
  #67
g35newbie3's Avatar
So this might be a dumb question but I'm at kragen and the guy there tells me no no no you don't use mobile 1 ATF for powersteering. You use normal powersteering fluid. So I don't know if I'm brain farting or what but I bought both in case. This is a must do job by the weekend. So your using mobile 1 auto trans fluid for powersteering?I even reference the manual but of course the fluid type wasn't listed. Help please. New to self servicing this new car
Old Nov 3, 2010 | 11:34 PM
  #68
Mr.202?
you can use Power Steering Fluid or Dexron III compatible fluid which M1 ATF is..
I personally would use the M1 since its compatible with the fluid in there already. But if the Power Steering fluid you bought is too then thats ok too.
Old Dec 1, 2010 | 01:57 AM
  #69
socialconflicts's Avatar
so power steering actually uses Automatic tranny fluid...?
Old Dec 1, 2010 | 02:08 AM
  #70
Mr.202?
Yep, But Dexron III compatible ATF
Old Dec 1, 2010 | 02:12 AM
  #71
ok, you said mobile 1 ATF is dexron III compatible? i was going to buy some today but wanted to double check.
Old Dec 1, 2010 | 02:34 AM
  #72
Mr.202?
Yep
http://www.mobiloil.com/USA-English/...exron_III.aspx
Old Dec 1, 2010 | 02:41 AM
  #73
do they only make it synthetic? and is that the best route?
Old Dec 1, 2010 | 10:11 AM
  #74
Mr.202?
I am not sure if its the "best" but ill assume its better then oem fluid since its part synthetic
Old Dec 2, 2010 | 03:01 AM
  #75
toymachine2009's Avatar
Sweet I will attempt this this Sunday mine is black
