PSA: Powersteering Fluid
Old Dec 13, 2010 | 08:39 PM
  #91
NFSP G35's Avatar
? = 2B || !2B
I just picked up a quart of Mobil1 Synthetic today.
I'll do this when I do my oil change. (very soon)
Probably drain via the hose underneath. I need to take the reservoir out and paint it anyway.
Old Dec 13, 2010 | 10:51 PM
  #92
surma884's Avatar
I just ordered my amsoil and turkey baster...lol. I got so much work to do. I have to change the spark plugs, belts, diff fluid, and power steering fluid.
Old Dec 14, 2010 | 08:37 AM
  #93
NFSP G35's Avatar
? = 2B || !2B
^Good thing none of those are difficult.
Old Dec 14, 2010 | 10:02 AM
  #94
Mr. G's Avatar
I don't seem to be able to get the video link on DIY PS change by bythabay to work. Anyone have an active link?
Old Dec 14, 2010 | 02:40 PM
  #95
thescreensavers's Avatar
Mr.202?
http://infinitihelp.com/diy/gsedan/p...stallation.htm
Old Dec 14, 2010 | 02:53 PM
  #96
Mr. G's Avatar
Thanks! After about two minutes into the video, I decided I would just go with the syringe or turkey baster method.
Old Dec 14, 2010 | 11:56 PM
  #97
kenasaki's Avatar
same here, my belts are all cracked. I bought it along time ago from nissan but I hope they are the right ones. I'll have to look for a How-to on the front belts
Old Dec 21, 2010 | 02:01 PM
  #98
kenasaki's Avatar
hey everyone, i went to autozone and the only thing he insisted on was the Castrol ATF made for imports to pour into my psw. Is this correct? I dont wanna stick the wrong thing in there. It doesn't say where its dexrone3 equivalent
Old Dec 21, 2010 | 03:11 PM
  #99
5150DS's Avatar
It says it on the back. I put the same thing in my car yesterday. If you want synthetic I believe you can get Mobil1 from Pep Boys or you can get Royal Purple from Oreilly's.
Old Dec 21, 2010 | 03:13 PM
  #100
5150DS's Avatar
Here: https://g35driver.com/forums/g35-sed...eo-series.html
Old Aug 28, 2011 | 12:25 AM
  #101
DFISH239's Avatar
I changed the tanks out and put ps fluid in and now my pump is making a grinding like noise or winding noise when i turn my wheel. what is wrong with it could i have put two much fluid in it
Old Aug 28, 2011 | 12:33 AM
  #102
TurTLe*'s Avatar
^ air pocket?
you literally took the tank out? Too much fluid would not make noise, too little or wrong fluid might also if you created a air pocket that could be it too.
My suggestion, get the front end on jackstands, start the car, remove the PS fluid cap and turn the wheel lock to lock about 10 times and see if the noise gets away, gets louder or w/e and post back.
Old Aug 29, 2011 | 01:23 AM
  #103
DFISH239's Avatar
ok imma get on that tomorrow
  #104
DFISH239's Avatar
yeah i did i was putting a tank in
Old Sep 14, 2011 | 10:36 PM
  #105
drinknother1's Avatar
since i just got my 05 g35x with 58,500, i saw this thread n bought mobil 1 atf. now when i went to go change it through the tank i saw the fluid still looked pretty red. to me it still looked good and not all gunked up. i have no previous service records on the vehicle. should i change it anyways or let it be? and i also realized my turkey baster was to damn fat to fit.
