cliclking noise from ouside the car
Old Jun 30, 2010 | 01:28 AM
nazc0's Avatar
2006 Vortech supercharged Sedan
wierdest thing happened 2 days ago, i get in my car start the engine and music and off i go and i acclerate and let off before a stop sign just in time to hear a trrrrrrrrrrrrrrrrrrrrrrrrrrr sound comming from the outside of my car, i thought it wasent my car so i just kept going with music and exhaust blaring and then the song ends right as i pull up to another stop sign and again trrrrrrrrrrrrrr sound, so now i turn off my radio and try to listen for it and i begin to crap my pants as it sounds like its coming from the right side of my car whenever my wheals arent under force like when i am accelerating i can only somewhat hear the noise but the moment i let off the gas when on an uphill i hear it loud as day, just like the sound of a ratchet being turned next to my ear really fast, so no i am oficialy scared ****less, i parked my car all day yesterday and was to scared to drive it but i had to drive it today and i could hear all the odd things again
also 2 more issues, after sitting the whole day yesterday when i get in the car today, starts fine but the moment i dropped it into reverse it just died instantly , so i thought it was just a fluke so i tried starting it and it was cranking and cranking like an old russian car that was on its last miles it took 4 attempts to start before it fired up and now i thought i was in deep **** so i went and filled up with 20 bux of premium thinking that there might have been verry little fuel in the car and after 26-29 hours worth of standing it somehow wasent all getting there so i crossed my fingers and went off to pick up my friend, and on the way back from his house about 3-4 hours later i get to a red light, and it goes green so i hit the gas about halfway and no more then 2 seconds later my car died and i lost everything power steering brakes and even turn signals, i thought i was going to crash but just kept rolling down the hill and with some luck there was a break in traffic to my right so i rolled off the street and put the car in neutral and it started right away, no hiccups at all, this is all verry strange for it to happen over a span of 3 days so i need some advice on how i should go about this the car has 104k miles and had a full service done to it at about 97k miles by bythebay, and it included everything full steering flush, tranny flush, brake fluid flush, coolant, diff, and new spark plugs, and drive belts and no expence was spared on parts i used all the best parts he could offer all the fluids were eather oem or amsoil fluids so now im just at a loss of what i need to do to keep my car happy
Old Jun 30, 2010 | 06:05 PM
nasman3188's Avatar
Try some more periods in your writing.... people much more knowledgeable than me might give you the time of day.
Old Jun 30, 2010 | 07:00 PM
2QU1CK's Avatar
03-05 had a recall with the rear axles. not a major issue but something needs to be taken apart and greese up. mine is like that for 1 1/2 year now, didnt get worse, but just annoying.
Old Jun 30, 2010 | 11:25 PM
nazc0's Avatar
is there a diy for it?
Old Jul 2, 2010 | 12:01 AM
heftylefty58's Avatar
x2!
Old Jul 2, 2010 | 12:24 AM
G35xChicago's Avatar
holy run-on batman
Old Jul 2, 2010 | 12:57 AM
AARONHL's Avatar
Didn't even read..
Old Jul 2, 2010 | 12:59 AM
Tollboothwilley's Avatar
Do a search for "AXLE CLICK" and I'm sure you'll find a lot of info. This is likely part of your cause. Have you checked your oil level? Engine stalling is a bad sign. You need to get the ECU read for DTC's. If it died on its own there is almost certainly a problem.
Get your Battery/Alternator tested at Autozone as well, just to rule those out for starting issues.
Old Jul 2, 2010 | 08:46 PM
nazc0's Avatar
i quit trying to understand my car an oil change fixed everything, including the axle click
Old Jul 2, 2010 | 09:17 PM
thescreensavers's Avatar
Mr.202?
An engine oil change magically fixed every problem even on the other side of the car?
Man what oil is that I want some.
Old Jul 2, 2010 | 09:41 PM
nazc0's Avatar
mobil 1 and i kid you now i cant hear the weird sounds, car starts fine and its on sale at kragen for 35 bucks for 5 quarts and and filter
Old Jul 2, 2010 | 09:48 PM
Mr.202?
^ lol. Its all in your head then.
rezendvous420
May 31, 2020 01:26 PM
Joshua615
Aug 31, 2015 12:29 AM
rping
Jul 26, 2015 09:53 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
cyrus32
Jul 18, 2015 06:22 PM
