LCA Bushings Done For!
Old Jul 1, 2010 | 04:24 PM
ckkone's Avatar
https://g35driver.com/forums/brakes-...-replaced.html
Old Jul 1, 2010 | 04:59 PM
OKStateG35's Avatar
I saw that thread a while back, but it's not really a DIY. I'm sure I can figure it out, but it's always nice to hear what things to avoid so you don't waste time repeating mistakes others have already made.
Old Jul 1, 2010 | 05:13 PM
XDR-V35's Avatar
its pretty straight foward for a diy.. the pressing out and in of the new bushing you can use a shop press or possibly a ball joint press
Old Jul 10, 2010 | 05:55 PM
XDR-V35's Avatar
just swapped them out today.. some usefull info if you decide to press them in and out yourself, to press old ones out i used a deep well 1-1/8" socket and to press the new ones in i used a 36mm socket, but note different sockets may have different wall thicknesses that could effect the effectivness. i did not do a diy, as i used a 20 ton shop press, something that i assume few people have in their garage. the old bushings were pretty tight to push out, the new ones i froze for a couple days to contract the metal a little and used all the supplied lube/grease and the pressed in pretty easy.
Old Apr 6, 2012 | 04:45 PM
fanatik35's Avatar
yea
Yeah my passenger side is gone too, and i replaced it two months ago. today at the dealer i found that the driver side is also bad. I was gonna buy both control arms but now you guys are saying its fixable... i asked a certified mechanic and he said it's not recommended! the alignment in my baby is REALLY bad what should i do?
Old Apr 6, 2012 | 05:20 PM
seymore4's Avatar
m56
You can replace them, you just have to use a bearing press and be careful. Lots of guys replace them with the SPL solid bushings (big handling upgrade) but most dealers and some mechanics will tell you to replace the whole thing because there isn't a lot of material around them and it is possible to damage the arm when you're pressing the bearings
Old Apr 6, 2012 | 06:25 PM
fanatik35's Avatar
Thank you! I understand. Would u recommand the whitline given in the previous post? And can I put them in my self?
Old Apr 6, 2012 | 06:36 PM
seymore4's Avatar
m56
I've never used whiteline personally so I can't say either way,
As for replacing them it all yourself it all depends on how mechanically inclined you are, lol. I would do it, but I also have a lift and 10 ton press in my shop
Old Apr 6, 2012 | 08:56 PM
fanatik35's Avatar
if you can do it i can do it! lol. wich bushing do u recommend?
Old Apr 6, 2012 | 09:06 PM
seymore4's Avatar
m56
I like spl pro suspension, but they will make it a little more intense lol should increase the handling too
Old Apr 6, 2012 | 11:05 PM
fanatik35's Avatar
Talking
NICE!! I'll look it up. Thank you!!
Old Apr 7, 2012 | 12:12 AM
seymore4's Avatar
m56
Here ya go!
http://www.splparts.com/chassis-Z33.html
If you need to pick up a camber kit or something as well I might be able to swing you a better deal through my buddy's shop, but if you just need those bushings a vendor like import parts pro will have the best price.
All around very high quality stuff tho, I've got it all around.
Old Apr 7, 2012 | 10:21 AM
fanatik35's Avatar
Oh yeah! I think I found my self a shop! Are you talking about front and rear kit
Old Apr 7, 2012 | 02:29 PM
seymore4's Avatar
m56
Yeah I have their front and rear camber kits, as well as bushings on my car
Old Apr 7, 2012 | 08:48 PM
  #30
Tollboothwilley's Avatar
I did a DIY on this a while back - it is easy to replace. I HIGHLY recommend replacing with poly-urethane bushings. I went with Whiteline and they are VERY worthwhile.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
TheBay
Sep 3, 2015 03:27 PM
