G35 Sedan
Old Jul 9, 2010 | 01:16 AM
hL.'s Avatar
hL.
G35 Sedan
Hi I'm looking into buying a 03/04 G35 Sedan. I've done some research and one of the main problems with the G35 is the thin brake pads. Is this an issue for you guys and are they expensive to replace?
What are some pros and cons about this car?
Much help appreciated
Old Jul 9, 2010 | 01:27 AM
G35xChicago's Avatar
i wouldnt worry about the brake pads, and they are cheap to replace if you want standard ones.
Pros: these cars are just awesome, great aftermarket community as you can see
Cons: you may spend a lot of money modding, cant really make them fast without spending serious money.
Old Jul 9, 2010 | 01:36 AM
04G35NYC's Avatar
I bought hawks hps for $115 shipped from riverside. front and rear pads.
Old Jul 9, 2010 | 01:52 AM
itgogitrev's Avatar
For someone in Canada, I'd get HPs instead of HPSs. HPSs need a little heat in them to start biting.
Old Jul 9, 2010 | 08:02 AM
NFSP G35's Avatar
? = 2B || !2B
I wouldn't worry about brakes, that's an easy fix
Pros: Lots of fun for a 4-door
Cons: Answering the same questions over and over
Old Jul 9, 2010 | 08:21 AM
Swivel's Avatar
Moderator
hL, what's your location? You should check out the Canadian section:
https://g35driver.com/forums/canada-36/
Old Jul 9, 2010 | 09:28 AM
blazeplacid's Avatar
bought my 04 with 36k and the brakes were fine.
they were still fine at 50k.
Old Jul 9, 2010 | 09:48 AM
azt108's Avatar
Get a later model. first gen is too annoying to mod. As stated above, there aren't any real gains without going FI. If you get the new g37's they are so restricted that simple mods will get you great gains.
Old Jul 9, 2010 | 09:53 AM
NFSP G35's Avatar
? = 2B || !2B
^Although for the price gap, you could afford to go FI on a first gen
Old Jul 9, 2010 | 12:00 PM
itgogitrev's Avatar
You're gonna get that no matter what forum board you're on.
Old Jul 9, 2010 | 12:45 PM
NFSP G35's Avatar
? = 2B || !2B
^Not on my car club's forum
Old Jul 9, 2010 | 01:06 PM
hL.'s Avatar
hL.
thanks guys
Old Jul 9, 2010 | 04:36 PM
Jeff92se's Avatar
Red Card Crew
My advice. Spend a bit more and get an 05+. Better brakes, better interior. I think better automatic tranny shift logic. It's worth it.
Old Jul 9, 2010 | 05:07 PM
OKStateG35's Avatar
Agreed. Unless it's an X, then he should get the '06 for the better brakes. Wish I would have known that when I bought mine.
Old Jul 9, 2010 | 05:13 PM
Jeff92se's Avatar
Red Card Crew
Good point. But it's not too bad to upgrade to the better brakes vs new pads/rotors for your old ones. I'm talking $400 for pads/calipers/rotors/lines.
