Anyone get the airbag recall done yet?
Old Jul 13, 2010 | 05:29 PM
Mustang5L5's Avatar
Originally Posted by miltoda
No letter received here either. Just so I get this straight. When you don't have anyone in the passenger seat, the airbag light is supposed to stay on? My airbag light comes on when i start the car and then goes off a few seconds later regardless of it I have a passanger or not. I never knew this was a problem until i read this thread.
Yes...but I am referring to the "pass airbag off" light.
So when the light is on, it means the pass airbag is off. With nobody in the seat or objects under 40 pounds...this light should come on.
My dealer tried 3 times to fix this after awknowleding a fault in the wiring and even purchased a new seat bottom from japan (took two months to come in) and it didn't fix it...eventually they just blew me off even though they couldn't demonstrate it working right in my car.
The only time it comes on for me is sometimes under 10 degrees outside...and only for a few mins here and there. Kinda hoping the recall had something to do with this particular harness.
Old Jul 13, 2010 | 05:30 PM
SN00P's Avatar
CLUB MODERATOR
well that one never comes on either since iv bought the car back in january
neither the airbag light in the cluster comes on nor the one next to the clock
Old Jul 14, 2010 | 01:09 PM
blklude98's Avatar
Mine only comes on when something Heavy is there and No seatbelt is used.
Old Jul 15, 2010 | 12:39 PM
g35newbie3's Avatar
Dropped my G off at the dealership at 730 this morning for an oil change. The guy told me there is an airbag recall and that he would be replacing the piece (which is a connector), regardless of the airbag light coming on or not. I let him know that I didn't receive a letter or anything yet, but let me know if they have the parts they will swap the connector out.
Said it would take him an hour and a half to get it replaced then I will be ready to go
Old Jul 15, 2010 | 03:11 PM
ccc123pm's Avatar
X
to clarify which lights will appear as a result of this defect:
Description of the Defect:
On some of the potentially affected vehicles, the wire harness connecting the Belt Tension Sensor (BTS) and the Occupant Detection Sensor (ODS) control unit under the front passenger seat can experience relative
movement possibly caused by vehicle vibration or passenger loading on the
seat cushion. In certain instances, the movement may cause the pin and
sleeve terminals in the connecter to rub against each another. If this
occurs repeatedly, it can cause wear and oxidization of the terminals, which
may cause the contact resistance of the terminals to increase excessively.
High resistance in the connecter can cause interruption of the signal from
the BTS to the ODS control unit. If the signal interruption is detected, the
passenger air bag is designed to suppress. If this occurred, the (red)
supplemental air bag warning light would flash and the (amber) front
passenger air bag status light would illuminate to alert the vehicle operator
that the passenger air bag is not operating
Old Jul 15, 2010 | 07:08 PM
Mustang5L5's Avatar
Well I'll be damned.....
Old Jul 16, 2010 | 09:09 AM
blklude98's Avatar
you got a new seat bottom out of it...
Old Jul 16, 2010 | 01:23 PM
Mustang5L5's Avatar
I did...and considering nobody ever sits in my passenger seat (or rear seat), i basically have a brand new seat!
Now if i could only get a new driver's seat.
Old Jul 25, 2010 | 08:06 PM
Mustang5L5's Avatar
Well, scratch that...got my recall letter today.
Prob make an appointment in aug.
Old Jul 25, 2010 | 09:55 PM
ccc123pm's Avatar
X
took long enough, got mine in the mail yesterday as well. Hopefully I can get it in this week before me and a friend head down to wash dc this coming weekend
Old Jul 26, 2010 | 12:40 AM
thescreensavers's Avatar
Mr.202?
Good, All it says is blah blah blah air bag and to make an appointment?
Ill be on the look out for it.
Old Jul 26, 2010 | 09:34 AM
Mustang5L5's Avatar
Yup. Pretty much.
Old Jul 26, 2010 | 10:37 AM
MeNmyG35's Avatar
Exclamation
Has anyone gotten the recall notice yet on the airbag issue with the g35? Kinda thought they said fixes would be going on starting in July.
Anyone get a letter yet? Anyone drop in and get it fixed? If so what does the invoice state? What part did they replace? The harness under the seat? Or more?
this is from my alldata . i suggest getting one year subscription for 30.00
it helps alot
'03 g35 sedan
Classification: RS08-005b
Reference: ITB08-024b
Date: October 9, 2008
SRS PRECAUTIONS DURING SERVICE
This bulletin has been amended to apply to all current production models. Please discard all earlier versions.
APPLIED VEHICLES: All Infiniti Models with SRS Systems
SERVICE INFORMATION
Information necessary to service the Supplemental Restraint System (SRS) safely is included in the "RESTRAINTS" section of the Electronic Service Manual (ESM) for each vehicle.
IMPORTANT: Turn the ignition switch OFF; disconnect both battery terminals; and wait at least 3 minutes before performing any service on the SRS.
Improper maintenance, including incorrect removal and installation of the SRS, can lead to a serious injury or death caused by unintentional activation of the SRS.
In addition to the cautions and warnings in the ESM, the following provides additional safety precautions:
- Do not use power tools (air or electric) when working near the diagnosis sensor unit (mounted on the vehicle floor) with the ignition switch ON. For example, when removing or installing a front seat or center console, or when working underneath the vehicle near the diagnosis sensor unit.
- Use of power tools (air or electric) can vibrate the vehicle floor. If the battery cables are connected and the ignition switch is ON, these vibrations can be detected by the diagnosis sensor unit and activate the SRS.
- Do not use a hammer (or any similar object) when working near the side air bag (satellite) sensor (mounted on the B-pillar) with the ignition switch ON. For example, when adjusting the front door striker with a hammer.
- Use of a hammer (or similar object) near the side air bag (satellite) sensor can vibrate the B-pillar. If the battery cables are connected and the ignition switch is ON, these vibrations can be detected by the diagnosis sensor unit and activate the SRS.
Old Jul 26, 2010 | 11:07 AM
B T's Avatar
B T
got my recall letter Saturday, its states that all affected cars will be serviced whether or not any airbag indication has been given
Old Jul 26, 2010 | 11:11 AM
  #30
MeNmyG35's Avatar
Red face
Ok well good luck
