Random Little Question Thread
#3841
^ 05/06 needs the 03/04 hardware to mount the HKS and the MD mufflers. Not sure about the others.
(1) Mounting Assembly Part #20742M
(2) Rubber Mounts Part #20651M
(2) Bolts Part #081468252G
Handy-dandy Infiniti exhaust components schematic
#3849
? = 2B || !2B
^What, just paint? It's easy, follow Chris' DIY: https://g35driver.com/forums/lightin...eadlights.html
The retrofit on the other hand was a huge PITA
#3852
#3853
I drove ttrank's car solo
On the Gs it does. From the factory when you floor it the throttle body is programmed to only open the throttle plate 75%. One of the benefits from a tune like Osiris is it removes this restriction allowing the throttle plate to open 100% when floored. It allows for immediate throttle response and eliminates the "lag" that's so irritating.
#3854
#3855
my car runs a bit rich i believe (black smoke at wot) i was hoping to correct it with a tune, i would love to get osiris but i can get a plug and play for less than 400 right now, hypertech or bullydog. not sure how good either of these are, i have ART pipes and full MD exhaust with popcharger, z-tube, 5/16th spacer, any ideas would be helpfull.......
