Random Little Question Thread
#4142
did my share of that too... that's ****'s nasty though - basically strychnine (rat poison) gvnmnt banned key ingredients after it become popular in 60s (just like they did MDMA/XTC)... Shrooms are organic and more controllable experience...
I havent done drugs in many years (we all grow up eventually)... but if I did, shrooms would be the ones... pot's organic too, but just makes you phucking stupid - can't stand being around idots completely stoned - I never liked that feeling anyway... stupid is not a good feeling but it's amazing how many pot-heads dont think they are stupid .
#4144
What percentage of coolant to water are you guys using in your radiators? I typically go with 60% distilled water and 40% coolant
that mixture gives the fluid a freezing temperature of -10 (i'm in Dallas so no prob), and a boiling point of 220. since water has the capacity to dissipate more heat than does ethylene glycol, i typically try to use 60% water
#4145
#4146
#4149
the dealer would need to test the sensors and the sending unit... best bet it to check pressure when the tires are completely cold (with a quality gauge, not those pos inaccurate stick gauges - I like analog dial, but many people prefer digi - both or better than the stick) ... inflate to 35 psi... if the light is still on after driving about 20min/20miles, then you probably have a bad sensor or sending unit... dealer would need to determine.
NFSP G35 (06-08-2011)
#4150
#4151
its a Redline product... I dont want to go into the physics (you can read about it) - but it has been independently tested to lower temps (not just by Redline, but various private)... I found out about it several years ago from DaveO when he was writing for SportZ magazine - he did some independent testing too and had good results... I've used it in my G for several years with good results...
Here's a link to the product:
http://www.redlineoil.com/Products.aspx?pcid=10
#4152
