Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Oct 18, 2011 | 09:27 PM
  #4996
CG4DR's Avatar
possibly for the line thats meant for the trans to radiator to cool
Old Oct 18, 2011 | 10:04 PM
  #4997
Ziltoid's Avatar
So, my heating is reeealy smelly(03 sedan). Do i need one of these?
http://www.autopartswarehouse.com/de...EPN420101.html
http://www.autopartswarehouse.com/de...EPN420104.html
If so, which one would you recommend?
Old Oct 19, 2011 | 05:51 PM
  #4998
thescreensavers's Avatar
Mr.202?
^ I bet there is a dead mouse in there or something lol, you can get the filter locally
Wix or Purolator are good.
Old Oct 19, 2011 | 08:15 PM
  #4999
Ziltoid's Avatar
I was exaggerating a little bit lol, it's not dead mouse bad, but it is a little unpleasant.(watch me find a dead mouse in there now haha). But thanks
Old Oct 20, 2011 | 06:49 PM
  #5000
gambit2083's Avatar
.. So heres one, best intercooler (s) for a OEM nismo sedan bumper. Dont want to hack it all to heck just to get one in there.
Thanks.
- Tori
Old Oct 20, 2011 | 08:45 PM
  #5001
Matzo Ball's Avatar
for those that ride low (spring owners do not qualify), do you still run an undertray? Mine is nearly ripped off and wonder if I should not use one or get a RareJDM metal undertray. Does the metal one sit higher than the OEM plastic one??
Old Oct 20, 2011 | 08:50 PM
  #5002
CandlestickPark's Avatar
ill Sedan
Dave, I went through 2 OEM undertrays and countless times of repairing them. It got to the point where the OEM one just wouldn't sit high enough and would be dragging everywhere.. I've been running the RareJDM under panel for over a year. Because I'm slammed I've installed it so that it sits higher than OEM. Instead of attaching it to the bottom of the bumper up front like the OEM one I made it so that it sits above the bumper against the frame (if that makes sense (its not attached to the front bumper). I've banged and scraped the under panel pretty hard on countless occasions and there isn't even a single dent in it, just some scratches.
Old Oct 20, 2011 | 08:54 PM
  #5003
ill Sedan
Thanks.
- Tori
If you are twin turbo and have dual FMICs (see below) then the Nismo bumper is perfect. If you have an FMIC that sits in the middle then the Nismo bumper (without modifying it) isn't a good option, look into getting a KuRookie.
Old Oct 20, 2011 | 08:55 PM
  #5004
ill Sedan
Originally Posted by matt_81108
any reason in particular the mishimoto radiator doesn't fit the automatic transmission?? custom car central . com did not inform me it fits only the 6mt when I called.
It fits a 5AT you'll just need to add an external tranny cooler.
When I added my Koyo radiator I had to add a tranny cooler, RRYDE made a nice bracket for me so it sits right behind the opening in my KuRookie bumper:
Old Oct 20, 2011 | 09:28 PM
  #5005
ronniepetras's Avatar
Is this the under tray I'm planning on buying one
http://www.zspeedperformance.com/03-09-350Z-03-06-G35-SDN-Aluminum-Engine-Undershrouds-V2-ZSP2001.htm
Old Oct 20, 2011 | 09:35 PM
  #5006
Blue Dream's Avatar
I drove ttrank's car solo
^^That's the one I have although I'm on my second one. I hit a tire tread about 18X18" square a while back going 60 in rush hour traffic and this is the effect of the impact on my first Z Speed.
The impact ripped the front of the tray from my bumper and bent it backwards 180 degrees and I drove the last mile and a half dragging the damn thing on the road. I'm too low to get under it and try to bend it back for the rest of my drive home.
Old Oct 20, 2011 | 09:44 PM
  #5007
Dayuuuum Tim anything happen to your front bumper?
Old Oct 20, 2011 | 09:49 PM
  #5008
Blue Dream's Avatar
Bumper no, but the impact punched a U shaped piece of my front lip in and put a 3" dent in the lip as well. I just popped the punched part back out so it looks OK from a distance but is very noticeable up close. My whole front end is sad looking at almost 100K miles with tons of rock chips and wear, so I'm looking at an 05-06 poly Nismo replica to go on next spring. I'm going to have my lip repaired and molded onto the new bumper at the same time.
Old Oct 20, 2011 | 09:53 PM
  #5009
ill Sedan
http://www.zspeedperformance.com/03-...V2-ZSP2001.htm
That's not the RareJDM one, you can get it from the below links:
http://www.injectedperformance.com/r...for350zg35.htm
http://www.z1auto.com/prodmore.asp?m...or&prodid=4911
Old Oct 20, 2011 | 10:16 PM
  #5010
Thanks Marcus!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
