Random Little Question Thread
#6181
After countless and countless failed search attempts ive decided to come and ask for help. I want to change almost if not all the vacuum, coolant, and radiator lines to the steel braided ones. I found out what sizes I need but I was wondering if there is a kit somewhere where I can buy the whole set? I dont want to individually buy the hoses and find out I bought the wrong ones, same with the fittings. Can someone help point me in the right direction? Thanks!!!!
#6182
on
^Um... basically the thread you just found: https://g35driver.com/forums/general...ml#post6424130
![Bowrofl](https://g35driver.com/forums/images/smilies/bowrofl.gif)
#6183
^Um... basically the thread you just found: https://g35driver.com/forums/general...ml#post6424130 ![Bowrofl](https://g35driver.com/forums/images/smilies/bowrofl.gif)
#6184
CandlestickPark (04-24-2012)
#6189
Received 1,486 Likes
on
#6190
#6193
#6194
I need would like someone opinion on the matter.
I am currently for an aftermarket set up that will allow me to change the color of the stock gauge cluster to a color of my choice. Does anyone know of a kit that will allow me to do it?
Also i am looking at putting in an aftermarket tach and gauges on my a pillar. Any good kits that are "a plug n go" type system. And i don't know how hard it is to take apart the dash so if someone could point me to a good reference i would really appreciate it
thank you
thank you
#6195
thank you
thank you
