Random Little Question Thread
Old Sep 10, 2012 | 04:06 PM
  #7156
albundy1987's Avatar
Originally Posted by G35Papa
I already have the iso thermal gasket installed. I would just need the throttle body heater and the gasket that goes with it.
Thanks, I think I will try and get just the heater.
Old Sep 10, 2012 | 04:08 PM
  #7157
TORETTO's Avatar
Originally Posted by ㄴㅇㅇㄱ™ ninja
How long does a gopro camera record for? Want to catch someone in the act that keeps keying or creating dents & maybe door dings to my car. I notice a new one every Sunday. Starting to annoy the crap outta me
wtf.
Old Sep 10, 2012 | 04:20 PM
  #7158
G35Papa's Avatar
Gotcha. They're a great company to deal with. I'm sure they would have no problem selling you just the heater.
Old Sep 10, 2012 | 06:50 PM
  #7159
AzuMaster's Avatar
Are the 03/04 Brembro Brakes set up better than Akebono's? Assuming both were new.
Old Sep 10, 2012 | 07:06 PM
  #7160
DVG's Avatar
DVG
From what I've read:..
Track use - brembos due to weight and variety of available parts
Every day use - akebonos because omg sexy
I plan to run akebono with 2 piece rotors
Old Sep 10, 2012 | 10:20 PM
  #7161
CG4DR's Avatar
What is a good OE replacement for the sedan fuel pump?
Old Sep 11, 2012 | 03:20 AM
  #7162
dofu's Avatar
20 Year Member
Originally Posted by Thegage1415
alright ive been reading about the plenium spacers and im sure ill be told to search for it but i already did couldnt fine the anser but I will be ordering a plenium spacer but the only thing is i have a strut bar/brace that i hadf put on it is a stillen and i was wondering would i be able to do a 1/2 inch or would i have to do a 5/16 and will there be a difference in hp gains?
This really depends on if you have an auto transmission or an 05+ 6MT, reason being the motor will be different. With an auto, the spacer will be beneficial, with the 05+ 6MT, you'll have the revup motor which won't benefit from a spacer alone. You'd want the MREV along with the spacer. As for which spacer - unless you're boosted, they're the same, so IMO stick with the 5/16.
I just moved to WI from NJ. I have the MD iso-thermal plenum spacer. I didn't get the copper one. Do I need to get the copper one for the winter here? Has anyone ever actually experienced a throttle body freezing? I know the copper is just the throttle body heater. I would probably have to make a special request to motordyne for it.
Thanks.
The copper piece is not exactly a heater, it's more of a bypass that allows a bit of heat so your throttle body won't freeze. With snowy conditions, people would want motor heaters, so I wouldn't risk it. Having your throttle body freeze up on you is not a pleasant experience.
Old Sep 11, 2012 | 08:49 AM
  #7163
TunerMax's Avatar
G35
My understanding is that TB heaters are there only to warm incoming air charge. They do this by warming the TB and Intake Plenum, which in turn transfers heat to the incoming air.
Warmer incoming air helps the engine warm up faster.
I cannot fathom a TB 'freezing'. And if it did, a TB heater would do nothing to help it. If the TB is frozen when you go to start the car, it's frozen, you won't be able to start the car. Which wont allow the coolant to flow, warm up, and consequently warm the TB.
Old Sep 11, 2012 | 08:52 AM
  #7164
TunerMax's Avatar
G35
What they should do is have the coolant flow to the TB Electronically actuated. Flows when coolant temps are below Operating Range, and shuts flow off when you reach or approach operating range.
This would allow quicker warm up time as well as increased performance from cooler air charge once the engine warms up.
Old Sep 11, 2012 | 04:45 PM
  #7165
dofu's Avatar
20 Year Member
Warming the air so it mixes with fuel better is more important in carbureted motors than it is with fuel injection. Technically, the materials newer motors are made of does not require any warm up time, you just need to run the motor long enough to get the lubricants flowing properly to properly protect your motor, transmission, etc...
They might have many reasons to have the coolant run through the throttle body, but you have to keep in mind that auto makers have a lot of liability on their hands, so making sure a part like the throttle body doesn't freeze and remain open on those rare occasions that can happen is a big deal, especially when there's a cheap and easy way of preventing it from happening.
If I remember correctly, it's happened to a few members on here before.
Old Sep 11, 2012 | 05:00 PM
  #7166
jdubin94's Avatar
So Im gonna get a transmission flush very soon to hopefully fix my problem. My problem is that shifting into 1st, 2nd and 3rd is pretty rough. Im hoping its not the synchronizers. I did some research and people who experienced the same issue as me said they replaced their transmission fluid with GM Synchromesh Friction Modified Transmission Fluid and it fixed their problem. However, I called inifniti today and they said that i have to use the oem fluid. They said any other fluid will damage my gearbox.. Is this true?
Old Sep 11, 2012 | 05:03 PM
  #7167
dofu's Avatar
20 Year Member
Synchromesh works great on Honda transmissions, not sure how great it will work with the G. If it is the synchros, most likely the gears will have been ground down a bit by now as well.
Old Sep 11, 2012 | 06:33 PM
  #7168
TunerMax's Avatar
G35
Originally Posted by dofu
More important with a carb, perhaps, but that's only because you couldn't adjust fuelling, etc at cold idle differently from operating temp idle really. this meant the engine would get to operating temp slower than a conventional engine with EFI.
EFI allows different fuelling for different temps obviously, so the engine can warm faster than it could before.
Cold start and idle are the #1 killers of engines. This is when the most wear occurs in traditional engines. OEM's go to great lengths to keep the engine OUT of those situations as much as possible. This means any means possible to get that engine up to operating temperature as fast as possible. The heated TB is one of the employed methods.
Not to say that potential for freezing TB's isn't there, and isn't part of the purpose. My focus is more on engine wear and cold-idling conditions though. In very cold climates where Block heaters are used, these coolant lines are most effective for both purposes, as well as helping cold-starts.
Old Sep 13, 2012 | 11:02 PM
  #7169
Max626's Avatar
The lights for the mileage is it a bulb or led board? if its a bulb what size is it.
Old Sep 14, 2012 | 12:55 AM
  #7170
TunerMax's Avatar
G35
T5
Bulb. Get it from Nissan if you can't get it froma wrecker. Not cheap but better than getting the wrong one.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
