Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Sep 18, 2012 | 11:11 AM
  #7216
seymore4's Avatar
m56
Originally Posted by Myvqg35
Does anyone know if 350z Kw v3 coilovers will fit a g35 coupe any help would be appreciated
yes they will
Old Sep 18, 2012 | 11:14 AM
  #7217
Myvqg35's Avatar
Ok cuz I looked them up and the part numbers change for the v3's only not the v1's or 2
Old Sep 18, 2012 | 11:44 AM
  #7218
Roh's Avatar
Roh
anyone know if a coupe GT spec STB will fit a 04 g35 sedan rwd?? also will it clear a 5/16 plenum spacer from motordyne? i prolly wont be running a engine cover after i get the spacer.
Old Sep 18, 2012 | 12:03 PM
  #7219
TunerMax's Avatar
G35
I know this has come up, the Rear Sway bar, can we use the 350Z one?
(I am planning a dual exhaust and the RSB from the 350 would allow it with much more space and simplicity)
Old Sep 18, 2012 | 02:20 PM
  #7220
ryanm8's Avatar
Are you sure on that? I always thought the 350Z sways were the same. As far as I know, the only sway bar to allow additional clearance is the Motordyne.
Old Sep 18, 2012 | 07:06 PM
  #7221
TunerMax's Avatar
G35
No, actually, I"m a dummy. I forgot the 'dual exhaust' on the G coupe and 350 is fake.
nevermind, lmfao
Old Sep 18, 2012 | 09:03 PM
  #7222
ryanm8's Avatar
OK, lol.
Clearance is pretty tight on a dual exhaust with 3" piping. The left side goes under the sway and the right goes over. I'm not sure how much additional clearance the Motordyne sways free up.
Old Sep 18, 2012 | 10:42 PM
  #7223
TunerMax's Avatar
G35
3" duals!?!?!? Nah, that's way too big. This isn't a 700 whp animal.
2.25" or 2.5" is the plan.
Old Sep 18, 2012 | 11:43 PM
  #7224
ryanm8's Avatar
Yes, 3" the whole way isn't a good idea unless you're pushing massive HP, but 3" after the merge is always better performance wise. That's how the Motordyne exhaust is. Might as well do it, especially if you're FI.
Anyways, clearance shouldn't be a problem with the stock sways as long as your exhaust hangers aren't really worn out and sagging. I know mine were after 9 years.
Old Sep 19, 2012 | 12:52 AM
  #7225
TunerMax's Avatar
G35
Duals, Duals, hence, Duals. lol.
2.25 or 2.5 DUALS.
Old Sep 19, 2012 | 12:54 AM
  #7226
TORETTO's Avatar
2.5" piping. 10" tips
Old Sep 19, 2012 | 02:07 AM
  #7227
VanCity G35's Avatar
Who has 18" g35 coupe wheels on their sedan?
Hey Guys,
Found a good set of g35 coupe 18" x 8" rims! 30 offset
I'm worried they'll stick too far out: 15mm less offset than stock + 12.5mm in wheel width (per side of hub) = the wheels sticking out more than an inch over stock.
Anyone with this set-up please advise.
Thanks!
Old Sep 19, 2012 | 02:12 AM
  #7228
dominate's Avatar
There are a buttload of threads on this, go to advanced search and search "+sedan +coupe +18" without the quotations
Old Sep 19, 2012 | 07:38 AM
  #7229
ryanm8's Avatar
2.25 or 2.5 DUALS.
I think you're misunderstanding me here. A proper dual exhaust is supposed to have a merge at some point close near the cats/test pipes (either via a Y-pipe or X-pipe). This is still a dual exhaust as long as you don't have a single pipe coming after the merge.
I suggest you take a look at the Motordyne exhaust and just copy that. It's been proven to provide the best gains.
Old Sep 19, 2012 | 09:35 AM
  #7230
g35indafuture's Avatar
Tokico hp shocks on Sports Suspension
Will Blue tokico hp shocks fit on my 04 infiniti g35 sedan (red shocks) sport suspension? I was going to buy these shocks, but I read the description saying it doesn't fit sport suspension.
http://www.ebay.com/itm/03-07-Infini...4b192e&vxp=mtr
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
