Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Sep 19, 2012 | 11:59 AM
  #7231
MrTBahgs's Avatar
Im in immediate need of a new exhaust system for my '06 AWD sedan, minimally midpipe and muffler. Been doing some research on a few and I come across some that will add in that they are not for the AWD models, but only the RWD sedans. What would be the cause of this to not allow it to fit my car? I dont think all sources for the same exhaust will state that it isnt for AWD models so I also wonder if its actually not true and they should work just fine.
The same thing has applied to test pipes not being allowed to fit AWD models.
So once that is explained I guess my simple follow up quesiton is, Which exhausts properly fit an AWD sedan (basically easy bolt on) so I can try and norrow down the field.
Old Sep 19, 2012 | 12:03 PM
  #7232
DVG's Avatar
DVG
Originally Posted by dominate
There are a buttload of threads on this, go to advanced search and search "+sedan +coupe +18" without the quotations
whoa, what do the +s do? Have I been searching wrong this whole time?
Is there a thread on how to search properly? I would search for it but ....you know
Old Sep 19, 2012 | 12:04 PM
  #7233
icekewl's Avatar
how is the wheel setup go where the wheel is cambered in and tires stretched all while being flush?
Old Sep 19, 2012 | 12:08 PM
  #7234
S 854's Avatar
https://g35driver.com/forums/g35driv...searching.html
Boolean search optimizes search results.
Boolean Searches
How do I do a Boolean Search?
You have two choices: you can use the standard Boolean operators (AND, OR, NOT, or NEAR, or you can use their math equivalents. It depends on you, the searcher, on which method you're more comfortable with. For example:
Boolean Search Operators
  • The Boolean search operator AND is equal to the "+" symbol.
  • The Boolean search operator NOT is equal to the "-" symbol.
  • The Boolean search operator OR is the default setting of any search engine; meaning, all search engines will return all the words you type in, automatically.
  • The Boolean search operator NEAR is equal to putting a search query in quotes, i.e., "sponge bob squarepants". You're essentially telling the search engine that you want all of these words, in this specific order, or this specific phrase.
Old Sep 19, 2012 | 12:10 PM
  #7235
DVG's Avatar
DVG
Can I use brackets as well? Eg. (+03 +sidemarkers) OR (+05 +taillights)
Old Sep 19, 2012 | 12:17 PM
  #7236
S 854's Avatar
^ Not sure - I don't think I ever went beyond adding the plus sign. You could try it but I don't think there'd be a point to refining beyond the + sign?
Post #2 in that linked Driver thread is where the good stuff is in reference to better searching over the all the site. Should make it a membership requirement somehow......
Searching on this site isn't as hard as it looks - you just need to refine the searching so it works better than just out of the box.
There are four main things you can do to get better search results when using the Driver Search Tool:
https://g35driver.com/forums/search.php
1. For your search terms (especially if they are commonly used all over), you can add a plus sign in front of each word - i.e. if you are looking for coupe springs you'd type in '+coupe +springs'
2. In the dropdown box beneath where you type in your search terms, you can change the option from 'Search Entire Posts' to 'Search Titles Only'
3. To refine even more, lastly you can narrow down the subforums for the search to run in by going over to the 'Search in Forum(s)'. Most of my searches would only be in the 1st gen sedan forum and the associated tech forum so I'd select only those two subforums (hold down the control button and click to highlight which forums only to search).
4. If you remember the member's SN who made a thread/post of something you wanted to read again, you can search using the 'Search by User Name' option and dropdown to search by post or thread.
Old Sep 19, 2012 | 12:23 PM
  #7237
S 854's Avatar
^ I don't own an AWD sedan so I don't know the specifics. IIRC it has something to do with the way the AWD undercarriage layout differs from the normal sedans so that pipes designed for the normal sedans don't get the same clearance. Maybe it's the transfer case....? Anyways, I THINK you'd be ok with just midpipe and muffler...usually it's the further up towards the front you go - y-pipe and HFC/TP that you run into issues.....My memory's hazy on this so don't quote me cause I'm spitballing here.
Your best bet would be to look in the 1st gen sedan subforum/sticky area for AWD guys discussing exhaust parts/options and maybe PM'ing one of them if you can't find the answer in one of those threads.
Old Sep 19, 2012 | 12:26 PM
  #7238
DVG's Avatar
DVG
Haha you have to pass the search test before you can post? Eg. Find a thread about x with this poster.
Old Sep 19, 2012 | 12:29 PM
  #7239
S 854's Avatar
Originally Posted by g35indafuture
Will Blue tokico hp shocks fit on my 04 infiniti g35 sedan (red shocks) sport suspension? I was going to buy these shocks, but I read the description saying it doesn't fit sport suspension.
http://www.ebay.com/itm/03-07-Infini...4b192e&vxp=mtr
^ Pretty sure suspension parts are interchangeable between 1st gen 350z/G35 coupes/G35 sedans from what I remember.
For complete clarification and confirmation before you take my word as final (it's not by a long shot), go to the Vendor Marketplace and ask one of the Driver vendors. They'd probably give you a competitive price too to boot.
Old Sep 19, 2012 | 12:35 PM
  #7240
DVG's Avatar
DVG
Pretty sure that this is just because of different spring rates in sport suspension / AWD.
I think you should always match dampers to springs or you will wear out the dampers faster. I have OEM non sport springs if you want them
But they will probably fit - I just installed 08 nismo z suspension in my 03 non sport sedan. pretty sure those are the most opposite you can get.
Old Sep 19, 2012 | 02:12 PM
  #7241
TunerMax's Avatar
G35
Originally Posted by ryanm8
I think you're misunderstanding me here. A proper dual exhaust is supposed to have a merge at some point close near the cats/test pipes (either via a Y-pipe or X-pipe). This is still a dual exhaust as long as you don't have a single pipe coming after the merge.
I suggest you take a look at the Motordyne exhaust and just copy that. It's been proven to provide the best gains.
Yes I'll be installing an H pipe of course.
I love his design, it's similar in most every way to the idea's I"ve had for this exhaust, just better. I have some research and testing ahead of me to say the least.
Old Sep 19, 2012 | 02:29 PM
  #7242
DVG's Avatar
DVG
Why H pipe over x pipe?
I had an H pipe on my borla and I opted to swap it for a x pipe. Flow just looks smoother to me, intuitively. When I looked at the inside of the H pipe, I also saw a lot of build up at the far sides of the connecting pipe, indicating that air was hitting the pipes at a 90 degree angle with high velocity. That seems like it would impede airflow to me.
Old Sep 19, 2012 | 07:05 PM
  #7243
TunerMax's Avatar
G35
In general, X-Pipe flows better but sounds more 'racy'. It is quieter.
H-Pipe doesn't flow as well, but sounds more 'muscular', deeper tone. They are more prone to 'drone' though, which is a negative benefit.
I just dont want raspy/ricey sounding exhaust. I know it's going to make a decent enough amoutn of power, I'll sacrifice 5-10 WHP for better sound, no question.
http://mbworld.org/forums/w211-amg/4...confusion.html
Old Sep 19, 2012 | 07:16 PM
  #7244
MOP1202's Avatar
I've tried to find an answer but nothing conclusive. Would the 2003 oem brembos from the coupe fit on a 2007 sedan?
Is it a simple bolt on or do I need the 2003 brackets in order to make it fit?
Thanks in advance
Old Sep 19, 2012 | 11:36 PM
  #7245
TunerMax's Avatar
G35
i'm fairly confident in telling you they will not bolt right up, but I could be wrong
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
