Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Dec 28, 2012 | 05:51 PM
  #7981
dominate's Avatar
Originally Posted by NeverTooFast
I have konig wheels, need to add spacers but the screws have to go through the spacer and the rim but they're not long enough to fi , what can I do to get longer studs?
What do you mean by what can you do? You can either buy spacers with built in extended studs, or just buy separate extended studs.
Old Dec 28, 2012 | 09:17 PM
  #7982
canehdian_guy's Avatar
Edited:
While bleeding my clutch the resovour went dry and I'm pretty sure I sucked a lot of air into the system. I filled up the resovour again and tried bleeding the lines again to introduce the new fluid and although old fluid drips out of the bleeder screw no new fluid is entering the lines. I'm sure of this because I drained about an oz of liquid and the resovour is at the same level prior to bleeding.
If anyone knows how I can get fluid back into the system I'd greatly appreciate it.
Thanks
Old Dec 28, 2012 | 09:40 PM
  #7983
The Stimulation's Avatar
Constantly having issues with my passenger ballast failing on me causing my headlight not to work. I unscrew it and out comes liquid (electrical fluid I suppose?). I'm on my 3rd or 4th one and don't want to keep replacing the ballast, and a new headlight is out the question. I don't have the funds for a $900 headlight (even with a discount I can get I'm looking at over half a grand for a single headlight).
I'm thinking about getting an aftermarket HID kit since I have one for my fogs (no issues) and just running those. Any other suggestions before I take this route or possible problems I may face going this route?
Old Dec 29, 2012 | 12:18 AM
  #7984
nascarbuff17's Avatar
So I replaced the break switch today, I was convinced it was the problem however it did not make any difference. It it a possibility that its the cruise control switch? I do not here anything from the center console, just a clunk from under my break pedal.
Old Dec 29, 2012 | 12:35 AM
  #7985
Update...
Originally Posted by nascarbuff17
Hello all, thought I would share some issues I am sure you have all had in the past and looking for answers.
First and foremost, My G35 will not shift out of park (unless I override the shift lock) and I here a clunk when depressing the brake pedal while starting the car. I also have no brake lights. When I scan the car, I get a C1142 brake pressure sensor error. I tested all my fuses with a lead and they are fine. My VDC, Slip, and ABC light is on (however, all work fine) When I use a test lead on the switches below the steering column I can activate them, shift form park and I have brake lights. I am all out of ideas.
Also, cruise control has recently stopped working, and the set light just flashes when turned on.
I replaced the brake switch today and that did not seem to make a difference. Any other ideas folks? I've topped the fluid, checked the fuses. Pads and rotors are also fine.
Old Dec 29, 2012 | 12:51 AM
  #7986
The shop doing a bunch of repairs for me picked up a refurbished one for me for $300. Looks brand new compared to my other one!
Old Dec 29, 2012 | 04:28 PM
  #7987
Kicknshift's Avatar
Am I really missing out if I go 03/04 over 05?
I've been searching and searching and I just cannot seem to find an 05 that I could actually buy money wise. My limit is $13,000 and most 05+ that I have seen are $15,000 or more and if not they are not in good shape.
I've already come across three 04's and two 03's that I can afford.
So would I be missing out? Only thing I know of is tail lights aren't as modern ( simple switch should do it ), the interior isn't as nice ( I can't tell a damn difference in black interior ) , that it has 18 less horsepower. ( manual tranny ) and it has oem 18's and I prefer 19's but that shouldn't be a hard switch.
What are some other things that are significant in 05+
Old Dec 29, 2012 | 05:47 PM
  #7988
TunerMax's Avatar
G35
This is not making fun of you, but damn did I when I read this.
OK, Let's make sure we have things clear.
Ballast =
There is only one way to 'unscrew' this, and that is during removal of the ballast, the 3 screws pictured.
These screws simply hold the ballast.
The ballast is a SEALED UNIT. It cannot leak. It cannot get water in it.
It could be argued that you HAD one that was bad and allowed water in, but not more than one, no.
So the real question here is WHERE is this 'liquid' actually coming from?
The only thing I can think is that it's coming from the CONNECTOR (PLUG) when you unplug it (grey piece shown with wires attached) If that's the case, you probably just need a new connector/seal, because it's allowing water in.
Elaborate as much as possible and post pictures as well to help expedite this
Old Dec 29, 2012 | 06:20 PM
  #7989
Ballast =
Lol. The "electrical fluid" I read about it or something somewhere else. It doesn't make sense to me, just throwing it out. But there is some fluid. I have the newer kind, where it's a darker grey and thinner, but basically when I pull out the ballast, there is some liquid and also inside the plug. It's not clear either, however, it can be just contaminated water. I can't recall the texture, but for some reason it felt oily if I do remember correctly.
My original headlight broke, got another one and the person had installed strobe lights in it. I sealed that off but there may be other areas where there is a crack, thus allowing some water in.
I'm considering just getting the HID kit. I found plugs to be used with my current one, however my bulbs don't match and the difference is only ten bucks. It'll involve more labor since I'll have to mount the ballasts, but might be the better way to go so I won't continue to have the problem. I just have no idea how the water is getting in if that's the problem. Perhaps from the tires slowly splashing water at the headlight? I have no fender line since it got chewed up when I was slammed. That's the only possibility I can think of.
Old Dec 29, 2012 | 06:23 PM
  #7990
DVG's Avatar
DVG
Don't downgrade from oem hids to aftermarket
Old Dec 29, 2012 | 07:19 PM
  #7991
TunerMax's Avatar
G35
Ahh I hear ya. The only thing I can think, if it's kind of 'goopy', is the sealant they use on the ballast to MAKE it a 'sealed unit'.
If that's the case, that sonofabishing thing must have gotten INSANELY HOT and literally melted it out.
Hmmm this is intersting. So we know that the wiring inside that headlight has been tampered with. Don't forget this important fact!
DO NOT DO THIS.
And I'm not even saying that for the obvious reason that Aftermarket kits are NOT as good as OEM.
I'm saying it because it's pretty clear to me that the problem is NOT GOING TO BE FIXED BY INSTALLING A HID KIT.
There's something else going on here from everything I hear. You simply don't burn through 3 or 4 ballasts for no reason, there's something else wrong.
Yes, it's very possible that you are getting water in there and it's frying something.
Have you had any issue blowing fuses? Is all the stock wiring original (not tampered with) on the CAR?
Also, you mention you have HID kit running the fog lamps in the housing. HOW are these wired exactly?
Pictures are really needed here for better answers/diagnosis man.
Either way, don't waste your money or time on an HID kit yet, not until we figure this out more. There's a lot of 'extra' stuff going on with wiring, etc on your car from what I hear, and that's probably the main cause.
First I need to see this 'liquid' in a nice picture or few pictures.
Old Dec 29, 2012 | 07:25 PM
  #7992
420OG35's Avatar
Akebono
Hey guys. So I came across what I think is a awesome deal. I won't say for how much but I came across a set of Akebonos with rotors.
Are these worth the price of having over stock or should I save that money and put towards something else.
Thanks guys
Old Dec 29, 2012 | 07:53 PM
  #7993
TunerMax's Avatar
G35
If you want looks, they're awesome.
If you want good Braking, they're awesome.
if you want performance, they're mediocre. The rotors are simply too heavy, and no one makes a reasonable, or even 'light' rotor for it yet.
Short form: they're mostly for looks, or long road courses. You will never use them anywhere else.
(I purchased a set of Akebonos).
Also, what you may consider cheap might not be as cheap as you think. They really don't cost much.
It's the adapter purchase (YOU NEED THIS) and the extra stuff that puts the price up. The calipers themselves aren't expensive at all.
If they don't come with adapters and all hardware, pads, etc needed, you might want to re-think just how 'cheap' they really are.
Post the price, if you want an opinion on it.
Old Dec 29, 2012 | 08:04 PM
  #7994
DO NOT DO THIS.
I'll have to get pics when I have free time, may not be for a week. I haven't gone through 3 or 4 ballasts back to back, it's over the time period of a couple years. Seems to happen when it rains.
I'm not sure how the HID kit for my fogs is wired, I had a reputable shop that's also a vendor on myg37 do the work. I haven't had any issues at all with that. The remainder of the wiring is all OEM. The strobe light is just the bulb. I sealed off as best as I can where the housing was drilled to fit the strobe. I haven't blown any fuses either. Basically whatever it is, just affects the ballast. Only thing I can think of doing to prevent water getting inside it is to use silicone or something where the plug meets the ballast. It's just a matter of having to carve that out when need be (if need be).
Old Dec 29, 2012 | 08:35 PM
  #7995
TunerMax's Avatar
G35
Sounds like you might be answering the issue yourself. No splash shield + a bad seal/plug = water in the plug.
water in the plug = short
short = blown ballast
Though a fuse should pick it up first, depending on how it's all wired. And it's been modified, so how it's wired seems to be anyones guess
Post the pic when you cant. For the time being if you have a working ballast, take the plug out, dry it with a hair dryer/compressed air/brake cleaner and reassemble. Put die=electric grease or vaseline on the connection and around it once connected.
Then wrap a bag around it and tape it up so no water that is being splashed at it can get in the plug.
This isn't the 'right way' but it is free, and will probably fix this issue.
Unfortunately, reputable means nothing. I've seen professional auto-electrician wiring that would make you puke. Most guys just do stuff until it works, there's very few people that do it right.
Doing it right takes too much time to justify with wiring in most cases, unfortunately.
Either way, there are other reasons I asked that, but for now, let's focus on this liquid/water, because it sounds like the most likely cause of this.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
