Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Dec 26, 2012 | 12:36 PM
  #7966
NEKST G's Avatar
Hello all, Im new to the Forum here.
Is it bad to take off the engine cover? I took mine off and lost the screws and just thought it'd be easier to leave the damn thing off. Is this ok? Any downside to it? I wouldnt imagine so, but thought id ask to be safe
Thanks
Old Dec 26, 2012 | 01:06 PM
  #7967
NFSP G35's Avatar
? = 2B || !2B
^It's just cosmetic. It's absolutely fine to run without one. All the best looking bays on the forum run no cover
Old Dec 26, 2012 | 01:17 PM
  #7968
NEKST G's Avatar
Thanks NFSP,
I guess I need to get my plenum polished because it looks nasty.
Old Dec 27, 2012 | 02:15 PM
  #7969
canehdian_guy's Avatar
How essential is it that I switch out the o ring on the radiator drain plug while flushing coolant? My heater is not working and it's -20C (-5F), so I'd like to switch my coolant to get the heater running asap but I don't know if its worth the risk.
Thanks
Old Dec 27, 2012 | 02:31 PM
  #7970
TunerMax's Avatar
G35
if its gonna leak itll do it right away.
if its still elastic and clean when you remove it, it'll be ok.
Old Dec 27, 2012 | 09:42 PM
  #7971
g35_white's Avatar
Two weird things happened today. Please help me solve them
1. The 3rd tail light went out. It doesn't come up at all. Not when braking, not when turning on lights. What could be the reason?
2. The transmission is in P mode. At that time, when i press on brake, i heard clicking noise coming from transmission. It disappeared in reverse and drive mode. What could be wrong?
And an off-topic question. I was to take a left turn at a photo enforced signal. The light was green but i was not so sure of making it so i slowed at the intersection as i hesitated, still the light was green but there was lots of flashes so i decided to complete the left turn. I looked behind, there was nobody. Did i do something wrong? Wil i get a ticket? I was under impression that it will trigger only if it is red which it clearly wasn't.
Thanks
Old Dec 27, 2012 | 11:02 PM
  #7972
TORETTO's Avatar
the problem is you have an autotragic transmission
Old Dec 27, 2012 | 11:41 PM
  #7973
thescreensavers's Avatar
Mr.202?
Originally Posted by NEKST G
Thanks NFSP,
If you want to clean it up, take it off the car, and use Mothers 05824 Pro-Strength Chrome Wheel Cleaner - and a Nylon wire brush and some scrubbing. Makes it look good as new
Before - http://i611.photobucket.com/albums/t...e/8fa09bea.jpg
After http://i611.photobucket.com/albums/t...503_013820.jpg
Thanks
1. Common issue on first Gens, Diode on the board dies/gets flaky and so that's why it might sometimes work, but in your case its completely dead.
https://g35driver.com/forums/g35-sed...yours-out.html
2. 100% normal
3. Redlight camera intersections like to flash for no reason at all, I wouldn't sweat it if the light was green. Though if the light turned red while you were inside the intersection then yea that could be a reason. Though nothing you can do until you do or do not get the ticket in the mail
Old Dec 28, 2012 | 12:11 AM
  #7974
g35_white's Avatar
2. 100% normal
Thanks Sir for the solutions.
1. Regarding the dead LED, what is alternative solution? I am thinking of getting a factory like spoiler with LED. I have quotes of around $150 and i guess $100 for installation. I am not sure how much it will cost to replace the LED lights but i am guessing at dealership it should be around $500.
2. The clicking noise didn't come till today. I have the car for 1.5 yrs and this is the first time i hear. So i am worried.
3. Till i took the turn, the light was green all the way. When i exit the curve it turned orange. At no point was it red. I thought may be it was flashing because i almost stopped on in the left lane before going through. I am still confused why this happened. I guess my best bet is to wait and watch and hope i don't get a ticket in mail. I am very careful especially when its photo enforced.
Old Dec 28, 2012 | 12:33 AM
  #7975
calcul8's Avatar
I can haz potato?
sabertooth tiger
This is not a helpful post Chris. Fun & games have their place
Old Dec 28, 2012 | 01:33 AM
  #7976
g35_white's Avatar
When he wrote that, i couldn't help laugh even though it was not helpful. I did wonder a minute after that why he said that. I thought may be he has a manual and he hates automatics.
Old Dec 28, 2012 | 01:47 AM
  #7977
rnguyen's Avatar
Sup guys I was just wondering has anyone painted their brake calipers and if so how did they come out
Old Dec 28, 2012 | 04:38 AM
  #7978
TORETTO's Avatar
Fun never hurts anyone Nate.
Unless it's a psycho with his ideas of fun.
Old Dec 28, 2012 | 06:56 AM
  #7979
TunerMax's Avatar
G35
Check the wiring to the brake light first, it's commonly known to rub through at some point either in the trunk or where it goes into the trunk lid. Search around, this is a common issue.
Its that or the board itself. If it's completely out, it's probably the wiring. If some of hte LED's work but others are out, it's probably the board.
Old Dec 28, 2012 | 03:38 PM
  #7980
NeverTooFast's Avatar
I have konig wheels, need to add spacers but the screws have to go through the spacer and the rim but they're not long enough to fi , what can I do to get longer studs?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
