Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Dec 29, 2012 | 08:41 PM
  #7996
TunerMax's Avatar
G35
Perhaps helpful for future diagnosing of a problem (applies to anything):
Root cause: The fault that created a chain of events leading to a failure
End Result/Resultant Damage: Anything that failed along the way, up to and including the final failure.
In your case, it's likely that the Root cause of the fault is a missing Splash sheild.
The splash shield allowed water to be sprayed at the ballast/plug whenever it was raining out.
Water damage is Resultant Damage
The water caused a short in the plug/ballast, also resultant damage
The ballast failed due to this short, also Resultant damage.
So we start from the End result (ballast blown) and work our way back examining all the stuff along the way, until we get to the splash sheild.
Seeing this form of trouble-shooting, it's easy to see why putting an HID kit on will not fix the Root cause of the issue.
We need to find the root cause, fix it, then fix all the resultant damage.
Of course, at this point, the above is all speculation, because the diagnosis isn't done yet
Old Dec 29, 2012 | 09:13 PM
  #7997
DVG's Avatar
DVG
Originally Posted by 420OG35
Hey guys. So I came across what I think is a awesome deal. I won't say for how much but I came across a set of Akebonos with rotors.
Are these worth the price of having over stock or should I save that money and put towards something else.
Thanks guys
Let me know if you need pads, I have some that I probably wont use
Old Dec 30, 2012 | 12:26 AM
  #7998
Airic214's Avatar
rays 19
LOOK GUIZE at what i bought for 400 what you guys think? tpms sensors came and all the lugs came with it too. but i need to replace the tires any one know how much that is going to run me per tire?
Old Dec 30, 2012 | 12:29 AM
  #7999
DVG's Avatar
DVG
I can't see the picture but I hope you aren't talking about the 18" sedan sport wheels
Old Dec 30, 2012 | 12:31 AM
  #8000
Airic214's Avatar
kslajdlkjf
no they are 19's i made sure i found a better deal on them but they have nissan center caps?
glad i didnt buy the 18's
Old Dec 30, 2012 | 12:32 AM
  #8001
DVG's Avatar
DVG
Good, they are the rays eng oem ones? Good find, I paid more for mine
Old Dec 30, 2012 | 12:40 AM
  #8002
Airic214's Avatar
yes im pretty sure they say forged on them. can you see the picture now? and any idea on how much the tires are going to cost me?
Old Dec 30, 2012 | 12:41 AM
  #8003
DVG's Avatar
DVG
I paid about 1200 for my tires
Old Dec 30, 2012 | 12:46 AM
  #8004
Airic214's Avatar
i didnt realize tires were so pricey
and here is the pic with forged
Old Dec 30, 2012 | 12:51 AM
  #8005
DVG's Avatar
DVG
They look good, yes tires are pricey but the difference in cost for the same tire in an 18 wouldn't be that much cheaper. I use continental dw. Tires aren't something to cheap out on
Old Dec 30, 2012 | 01:05 AM
  #8006
Airic214's Avatar
yea idk i think i might just buy a set of used tires to save money
Old Dec 30, 2012 | 01:09 AM
  #8007
DVG's Avatar
DVG
Well shop around first. You could certainly do cheaper than I did. I live in Canada so I have to pay more for everything. The real problem is that its an uncommon wheel size. 18 and 20 are both more popular, 19 is probably the least popular reasonably size wheel diameter. And yet it seems to be nissans favorite
Old Dec 30, 2012 | 01:37 AM
  #8008
HoodSTar457's Avatar
hey guys im new to the g35... but i was told that the uprev motors r better.... i have a 2005 g35 coupe..and is wondering is my g35 is a uprev motor..... thanks !!!! u or how i can find out if my g35 is a uprev motor...
Old Dec 30, 2012 | 01:44 AM
  #8009
TORETTO's Avatar
nobody has an uprev motor
Old Dec 30, 2012 | 01:52 AM
  #8010
nobody have a uprev motor?? so what does uprev means...
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
