Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Sep 15, 2012 | 11:51 AM
  #7186
b2autodesigns's Avatar
The coupe exhaust will not fit the sedan.
Charles
Old Sep 15, 2012 | 12:19 PM
  #7187
DR.D69's Avatar
Originally Posted by shiestan
HI I ORDEred this exhuast system for cheap off amazon and it said it fit the sedan version when. i got the box today it said COUPE on it. Does it still fit the sedan version or is there an easy way to fabricate it so it fits???
THANKS alot GUYS!!!!
like charles said it will not without some pretty serious fabrication.
Old Sep 15, 2012 | 04:38 PM
  #7188
rnguyen's Avatar
What would the HR y-pipe do to my car if i get that??
Old Sep 15, 2012 | 05:18 PM
  #7189
dofu's Avatar
20 Year Member
[rnguyen;6571566]What would the HR y-pipe do to my car if i get that??[/QUOTE]
Its just a better y-pipe.
Old Sep 15, 2012 | 06:13 PM
  #7190
rnguyen's Avatar
Originally Posted by dofu
k3oo83=rnguyen;6571566]What would the HR y-pipe do to my car if i get that??
Its just a better y-pipe.[/QUOTE]
Ok thanks for everything!
Old Sep 15, 2012 | 09:03 PM
  #7191
TunerMax's Avatar
G35
I you are asking about the speedo and tach, it'll still be amber. Yes, there is a filter that you need to scratch off. There is an extensive write up about this by a member of this community that goes by accordfreak.
I found that after I did it to mine, lol. Here's my thread, Sanding the gauge face starts @ POST #34
https://g35driver.com/forums/lightin...pic-heavy.html
DVG, I actually have the original KM/H gauge face, already sanded down ready to go, if you want to change the colour of your gauges.
Old Sep 15, 2012 | 09:10 PM
  #7192
DVG's Avatar
DVG
I kind of want to change everything to a white and red theme.
How is the 03/04? Can I just swap out LEDs / put in LED bulb replacements for everything?
Im somewhat interested in taking that gauge face off your hands, you're working on getting a custom one built right?
^I accidentally wrote 05/06 before, not sure how I got both numbers wrong...
Also, it looks like that part Im talking about is the one still-amber part in the interior, is there a way to do it?
My worries are:
The total km display
The climate control display
The radio
I dont care if red or white, but I need to be able to change those if Im going to start this project
Old Sep 16, 2012 | 01:01 AM
  #7193
Roy Ruggiero's Avatar
Has anybody put some LED license plate light bulbs in? I would appreciate pics and info!
Old Sep 16, 2012 | 02:05 PM
  #7194
g35_white's Avatar
Guys, 2 question. Have a 05 sedan.
Have to replace wipers. Which brand do you recommend? Bosch is good? Any DIY to install it?
Also the PS fluid is going black so may need to be replaced soon, was wondering if there is a DIY. found one for 2007 and up G35 but not for 2005. Will it be same?
thanks
Old Sep 16, 2012 | 02:16 PM
  #7195
thescreensavers's Avatar
Mr.202?
thanks
Bosch are decent, its pretty simple to install, they should come with instructions.
For power steering look here
https://g35driver.com/forums/g35-sed...ing-fluid.html
Old Sep 16, 2012 | 02:20 PM
  #7196
TunerMax's Avatar
G35
Yes, 05/06 and 03/04 are different. The 05/06 uses 2 bulbs, the 03/04 only has one.
I will post what I did to my 03/04 later, doing a big picture-purge right now.
In already have my custom one installed and pretty much done. The old one is just in my basement packaged up neatly not doing anything.
The LED job is not a simple tit-for-tat job, no. The 03/04 uses all incandecent lighting, to put LED's in you need to install it all yourself from scratch. Look through that thread I linked, see the ribbon-strip lighting I chose to use? That's the best option you have, get it in whatever colour you want.
I'd recommend white ribbon strip around the outside where the numbers are, then custom-mount some 3mm RED LED's under the needles.
As for the rest of the lighting in the car, I'm warning you now, it's a big job. But I'll help your questions. I haven't done the Radio unit yet, but I just finished the LCD screen.
Old Sep 16, 2012 | 11:39 PM
  #7197
G37x rims on a G35 sedan?
Does anybody know if these rims will fit on my 03' G35 sedan?
Attached Thumbnails Random Little Question Thread-5nd5l85g43g53m43n5c8sdfe9a74ba2eb1cf4.jpg
Old Sep 16, 2012 | 11:58 PM
  #7198
g35_white's Avatar
Thanks. That was very helpful.
  #7199
3truman's Avatar
Yes but you need the new lugs to go with those wheels, if im not mistaken, the newer wheels have different lugs fron your factory ones.
Old Sep 17, 2012 | 12:03 AM
  #7200
DVG's Avatar
DVG
Im having some serious problems with limp mode, can you guys look at this thread and contribute if you have any ideas?
https://g35driver.com/forums/engine-...l?#post6572543
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
