Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Aug 25, 2012 | 07:21 AM
  #7036
WILLIE BEANS's Avatar
Lol @tuna
Old Aug 25, 2012 | 10:50 AM
  #7037
NjMatteSedan's Avatar
Will my alignment really get messed up if I replace the lower ball joints and lower control arm bushings?
Old Aug 25, 2012 | 11:03 AM
  #7038
superG-coupe's Avatar
Originally Posted by G35Papa
That would suck if it was
Are you using an impact socket? If you are try using a regular one instead as they have thinner walls. Its been a while and i can't remember exactly what I used. How were you able to fit an impact gun? If you used an air wrench they don't have enough torque to break that bolt loose
i was useing 17mm, that might might be the problem, im not sure what the correct size is, it got the drive shaft nuts off, i had to take some deflector off the muffler to fit the impact, and it was air powered
Old Aug 25, 2012 | 11:44 AM
  #7039
5150DS's Avatar
They used to make them factory, but the were like $150 for each emblem.
Old Aug 25, 2012 | 12:37 PM
  #7040
Blue Dream's Avatar
I drove ttrank's car solo
Has anyone else seen/dealt with this? The top half of my odometer illumination is dimmer than the rest of the dash lights. This issue comes and goes. Sorry for the crappy phone pic, the pic doesn't really show the difference.
Show more
Old Aug 25, 2012 | 01:04 PM
  #7041
MPG35fiend's Avatar
muy malo. i had something like that happen to me, but mine completely went out off and on. had to replace the cluster gauge. luckily my warranty covered it bc it was like $800!
Old Aug 25, 2012 | 01:29 PM
  #7042
dofu's Avatar
20 Year Member
A bulb back there needs to be replaced.
Old Aug 25, 2012 | 01:49 PM
  #7043
TunerMax's Avatar
G35
They're LED's, can't just replace them unfortunately
Show more
Cant see an issue in that picture, but it sounds like you have a string of LED's (probably 3 of them) with one going bad, they're wired normally 3 in series at a time, so if one goes bad it takes the other 2 with it.
It can be fixed but not a the dealer, etc, you need someone who does LED stuff. LEDmod.com (hit up marcus) can fix it or convert it, as an option.
Old Aug 25, 2012 | 01:54 PM
  #7044
MPG35fiend's Avatar
yea thats what the dealer told me... they don't have bulbs just LEDs. the only way they could fix it was to replace buy cluster gauge... got an OEM part with a lifetime warranty so even if paid for it out of pocket it would of been well worth it.
Old Aug 25, 2012 | 02:24 PM
  #7045
Roy Ruggiero's Avatar
Originally Posted by unvmyg
Just plastic dip them easy to spray on and take off if you don't like it.
http://www.plastidip.com/
I don't like the flat black look. Also the glossifier and metalizier didn't seem to work long for me...
Old Aug 25, 2012 | 02:32 PM
  #7046
ArkansasG35COUPE's Avatar
Im with Roy... They dont have any depth with the plastidip, even with the gloss. Ebay is out too! I have my money ready for anyone that can come up with a set...
Old Aug 25, 2012 | 03:00 PM
  #7047
IIIHawKIII's Avatar
duplicolor metalcast.
Old Aug 25, 2012 | 03:04 PM
  #7048
I saw that one person did it them selves. Here is the link. Post #10
https://g35driver.com/forums/g35-cou...ti-emblem.html
Old Aug 25, 2012 | 03:42 PM
  #7049
JWT Procharger & Z-Tube?
I hear this is a very popular mod... Where should I buy it from?
Old Aug 25, 2012 | 04:29 PM
  #7050
P8NTBALLG35's Avatar
got mine from conceptzperformance.com also try z1motorsports. ive had great luck with both companies
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
