Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Feb 19, 2013 | 01:17 AM
  #8686
JDMswagSerf's Avatar
So I got an eBay intake. the nipple for the pcv valve was a nylon nipple that screws into the intake.
I thought it was a bit sketchy and thought that I should put silicone around it to ensure a good seal. but I didn't and now I have a fluctuating idle.
I also cleaned the throttle plate a little.
power feels the same, but at a stop it jumps around + or - 200 rpm from 1k-800 rpm.
im going to remove the intake an put silicone around the nylon nipple now. just curious if anyone had this problem before.
only other possible thing I see is air entering thought the couplings. but I tightened those. up as much as I could.
someone give me hope and say its most likely that crappy nylon nipple lol.
Old Feb 19, 2013 | 09:35 AM
  #8687
DVG's Avatar
DVG
It might be the nylon nipple, I took the precaution of applying silicone there.
But I bet its the throttle plate. You can throw it out of calibration really easily by touching it. Try a throttle position learning reset. Didnt work for me though, I had to take it to a dealer when I did that.
Old Feb 19, 2013 | 10:56 AM
  #8688
damn. while cleaning I did push it back a little. and since it's electric I know you're not suppose to do that with electric throttle plates. damn.
Old Feb 21, 2013 | 01:59 AM
  #8689
Lazy912's Avatar
Didn't wanna start a new thread over this, but I need a solution. Since I bought my G, the navi control trim/frame seems to be loose. So I tried to glue it with crazy glue and that didn't hold for even a day. Skip a couple of weeks, my genius cousin says he got it... he put some 3m double sided tape on it and made it all uneven. So before I even get to see what he did, he tries to remove it. Now its all beat up and bent up. Is it possible to replace or am I stuck with it? Can I remove it and try to make it straight? Any advice would be appreciated.
Old Feb 21, 2013 | 07:59 AM
  #8690
TurTLe*'s Avatar
^ i think you can remove it and straighten it a bit out. Its a METAL peice so the crease will be there and it will almost never be back 100% but you can get it close which is a LOT better then now.
Old Feb 21, 2013 | 08:33 AM
  #8691
(G35)'s Avatar
05/06 sedan tail lights
Does any body know where i can get a pair of 05/06 tail lights?
Old Feb 21, 2013 | 09:56 AM
  #8692
forestzemel's Avatar
K&N Filter + Ztube?
I was looking at Air Intakes and see people posting about Z Tubes? I know what a CAI is but what exactly is a Z Tube?
Is there anyone that can link me to a K&N CAI + Z Tube for my model so I can get an idea of this? Maybe an explanation. THanks so much ahead of itme.
*** Sorry for the noobness of mods
Old Feb 21, 2013 | 12:46 PM
  #8693
thegreatkwijibo's Avatar
The Z tube is the intake they use on a 350z. These engines don't tend to gain a lot of power if any from intake mods, so most people just buy the stock intake for a 350z, which makes more noise for sure, and arguably will make a bit more power. as for a link to a CAI Check the marketplace there's plenty of places selling em.
Old Feb 21, 2013 | 02:24 PM
  #8694
So what about a g35? I'm a new owner of an 06 g35 coupe I heard the stillen filter ztube kits make it sound better and have better gas mileage.
Old Feb 21, 2013 | 02:29 PM
  #8695
Well a lot of people put the z tube on their g. I don't know much about the Stillen kit but I know a lot of people like the z tube because of the sound and the fact that unlike a lot of intake options it doesn't seem to lose power. If you're really concerned with power/fuel economy you're first mod should be a plenum spacer, the best of which seems to be the motordyne 5/16" iso thermal.
Old Feb 21, 2013 | 02:32 PM
  #8696
Awesome! Thanks so much for the great advice. Not concerned about power and fuel more so just curious. That and I can't wait to start doing some fun stuff! I'm new to engine mods and all that so it's intriguing.
Old Feb 21, 2013 | 02:38 PM
  #8697
NP man gl with your build
Old Feb 21, 2013 | 03:11 PM
  #8698
is it hard to change the brakes on the g35 sedan?
one of my rears has ****ed up my rotor.
and the fronts are already starting to squeak with the low pad indicator pin.
so I'm just gonna get new pads as rotors all around.
it'd be nice if I changed them today. but I don't know if it'll take long....?
Old Feb 21, 2013 | 03:31 PM
  #8699
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
You can get the rears done in like 30 minutes total
Old Feb 21, 2013 | 07:17 PM
  #8700
ok cool thanks.
in just going to change them tomorrow. going to get drilled and slotted rotors and new pads.
this is irrelavent to this. but I cannot believe how easy it was to change te rear springs. each one took like 10 min. it was awesome lol
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
