Random Little Question Thread
Old Jan 10, 2013 | 01:25 PM
  #8281
Ednica87's Avatar
I'm 6'2" and can't stand sitting in the driver seat! I feel like I'm in a truck cuz it sits so high. Do any other drivers have this problem and have done something about it? I've moved the seat as far down as I could.
Posted from G35driver.com App for Android
Old Jan 10, 2013 | 01:31 PM
  #8282
DVG's Avatar
DVG
Coupe seats are the fix I've heard, but I feel you
Old Jan 10, 2013 | 02:28 PM
  #8283
thegreatkwijibo's Avatar
I'm thinkin of gettin a k2 front can anybody tell me what sides look good with that?
Old Jan 10, 2013 | 02:43 PM
  #8284
dominate's Avatar
Im having my nismo rear from ionic painted, and i want the scheme to be like OEM. Should I ask for the lower part to be satin black? Flat black?
Old Jan 10, 2013 | 03:02 PM
  #8285
JDMswagSerf's Avatar
Originally Posted by DVG
No, you need d2r
yea I just looke at the bulbs now and they're different.
so factory I have hid high and low beam?
and I just looked up the light bulb codes for the hid equipped car, luckily the foglight bulbs are the same size so I won't have to return those.
just to verify in this picture.
the very bottom bulb right bulb is where the new hid bulb will go correct?
the very tiny bulb is the turn signal bulb?
the bulb in the top right is the foglight bulb?
and what is the the empty connector for?
if I have any of these mixed can you please correct me.
Old Jan 10, 2013 | 03:30 PM
  #8286
Peoria35sedan's Avatar
Bottom is Fogs / Highbeams
Tiny bulb is turn signals
Top Right is the City Light
Empty Connector is where your low beam should be. DId you have headlights?
Old Jan 10, 2013 | 04:00 PM
  #8287
kjchevy3's Avatar
Here's my randon little question. I have noticed on my '04 sedan the front turn signals are not on when the lights are - they hve a single filament bulb. I have seen the discussions that include the number for the double filament. My question: Has anyone put the double filament in? Will it fit? Generally there are notches in the receptacle and I don't really want to take the car apart only to find the double filament bulb won't fit. Thanks.
Old Jan 10, 2013 | 04:04 PM
  #8288
DVG's Avatar
DVG
A double filament bulb will fit, but it will only act as single filament. You need to get a 7443 socket and modify it to fit, as well as get new gaskets to fit it. You will then need to wire it up. I've done it, it looks great, but I have white city lights. IMO no light there looks better than an amber light
Old Jan 10, 2013 | 04:06 PM
  #8289
DVG's Avatar
DVG
Reread what I wrote a while ago for low beam vs high beam and the bulb in the brown socket is the turn signal. The tiny bulb is a city light. The empty socket is for the hids. D2r. Did your car not come with a bulb here...? (wtf)
Old Jan 10, 2013 | 04:35 PM
  #8290
NFSP G35's Avatar
? = 2B || !2B
@ guy with seat question: 350z seats bolt up and sit crazy low.
@ guy with blinker question: this is one of the little differences between 03-04 and the05-06
Old Jan 10, 2013 | 04:38 PM
  #8291
DVG's Avatar
DVG
Can you link to anyone thats done a z seat swap? I didn't think it was straight forward to fit them. Would open up new possibilities for me!
Old Jan 10, 2013 | 06:11 PM
  #8292
Nope it didn't come with the bulb. there.
okay tiny bulb city lights
brown socket bulbs turn signal
lower bulb foglight/high beam
empty socket, hid bulb
if all that's correct I guess I was just driving around using my foglights since I dot have an actual hid low beam.
now I get it. the foglight and high beam is one bulb and the hid bulb alone is only the low beam correct.
Old Jan 10, 2013 | 06:14 PM
  #8293
DVG's Avatar
DVG
Yeah, I'm kind of baffled that someone sold you a car without even mentioning that
Old Jan 10, 2013 | 06:21 PM
  #8294
NFSP G35's Avatar
? = 2B || !2B
No link. But I saw it (and sat in) at Zdayz.
The guy said the brackets matched up, but he had to get longer bolts and put washers because they sat too low for his comfort.
Old Jan 10, 2013 | 09:18 PM
  #8295
me too!
now it makes sense why I couldn't see at night when I turned the low beams on and I had to turn the foglight switch. I was like wtf.
I guess both bulbs are missing or the left side is a bad bulb. cuz only the city lights turn on when I flip the light switch, and 1 city light doesn't even work!
I was driving just on foglights.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
