Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jul 31, 2012 | 02:08 PM
  #6781
Lake's Avatar
Motordyne Plenum spacer
Hi Guys
Im in Suriname South America .
And i have a 2006 5AT G35 Sedan .
Can you please advise what will be the best Motordyne spacer to use .in order to gain the most HP , and do i need a MREV .
And has any one install this on there 06 5AT already .
Thanks
Old Jul 31, 2012 | 02:16 PM
  #6782
Mr. Brett's Avatar
Search is yo friend.
Old Jul 31, 2012 | 02:26 PM
  #6783
SkylinesTheLimit's Avatar
Since your a 5AT you're not going to need the MREV2. If it gets really cold where you are, get the iso thermal. If not, just get the basic. Either way get 5/16
Old Jul 31, 2012 | 02:29 PM
  #6784
seymore4's Avatar
m56
Just get the basic 5/16" spacer. You do not need mrev. Everyone has one on their 5AT.
lol
Old Jul 31, 2012 | 02:41 PM
  #6785
Lake's Avatar
Hi Skylines
Thanks alot for the advise , its around 32o degrees cellius where i am .
  #6786
04nismoG's Avatar
Check this out http://my350z.com/forum/intake-exhau...ml#post7276118
Old Jul 31, 2012 | 03:13 PM
  #6787
Lake's Avatar
Plasma Direct Coil-Over Plug Ignition P/N PD6003401R
Hi Guys is it worth installing Plasma Direct Coil-Over Plug Ignition on 2006 5AT G35 Sedan. and whats the gain if yes .
Old Jul 31, 2012 | 03:42 PM
  #6788
Leland King's Avatar
K&N Air intake
Is anyone running a K&N air intake on this g35? Im looking to purchase one, just seeing if its worth the wild..
Old Jul 31, 2012 | 04:07 PM
  #6789
MannyFresh's Avatar
Megan racing test pipe
I have a crack right in the flex pipe.
Does anyone know the length of the flex pipe?
I'm not sure if it's 2.5 x 4".
Old Aug 1, 2012 | 12:14 PM
  #6790
fsiddiq3's Avatar
Unrevised Coupe Springs?
Hello all,
I have an 06 sedan sport, found some cheap coupe springs of an 04 coupe (I believe they are unrevised), how much of a drop would this give me and would I need to do an alignment afterwards?
  #6791
fsiddiq3's Avatar
and also can I still use my OEM struts wit this set up?
Old Aug 1, 2012 | 12:21 PM
  #6792
DTRUONG_112's Avatar
Need some input here, trying to purchase a CAI for my 2003 sedan and came across a couple models that reference "rectangular maf only". I was searching around and couldnt find many threads that were helpful. Only thing was if you have an early 03, you need circular housing. This is what I have:
The maf is rectangular, but I cant tell if the housing is considered rectangular. Can anyone provide some guidance or feedback before I actually create a new thread.
Old Aug 1, 2012 | 12:49 PM
  #6793
JaE35's Avatar
Moderator
G35 Sedan
What intakes brands are you considering? If you daily drive your car i'd invest elsewhere unless you don't mind sucking hot air into your engine
Old Aug 1, 2012 | 12:50 PM
  #6794
TunerMax's Avatar
G35
I try to refrain from anything resembling a flame in this thread, due to it's intended purpose, but REALLY?
Also you can likely put one in that's jsut a bit bigger, that will be easier because you'll have to cut the old one out and weld the new one in. If you get one a bit bigger it will give you more material to work with.
Old Aug 1, 2012 | 02:28 PM
  #6795
NFSP G35's Avatar
? = 2B || !2B
Take out those two torx screws (don't lose them) ; and pull the MAF module out. Is the hole circular or rectangular?
Just looking at the pic, I'd guess circular, but you should pull it just to be sure
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
