Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Aug 1, 2012 | 03:55 PM
  #6796
DTRUONG_112's Avatar
Originally Posted by JaE35
What intakes brands are you considering? If you daily drive your car i'd invest elsewhere unless you don't mind sucking hot air into your engine
Im really getting it for the looks in the engine bay. I found a fujita for an 03. Just have to make sure it will be compatible with the MAF that I have.
Old Aug 1, 2012 | 03:59 PM
  #6797
dofu's Avatar
20 Year Member
IMO, if you just want looks, invest in a chrome z-tube instead. This way you won't be losing useable power.
Old Aug 2, 2012 | 05:07 PM
  #6798
fdimola51389's Avatar
best option?
Hi guys, looking for a way to install an aux port in my 05 g coupe. Is there some aftermarket way to do it or do i just have to get a new headunit? if so is there a way to make the headunit work with the steering controls? thank you
Old Aug 2, 2012 | 05:30 PM
  #6799
VincenzG35's Avatar
What's the Best way to remove a dent there's no marks on the paint some hater kicked my car in the parkinglot while I was inside I have a dent above the gas tank
Old Aug 2, 2012 | 05:31 PM
  #6800
neo_anderson302's Avatar
Is their a cover for this?
Rear of center console
I asked the dealership but they say no.
But it looks like there should be.
Old Aug 2, 2012 | 06:19 PM
  #6801
bizz518's Avatar
brake condition question
Just had a few things fixed on my car today. The dealership does a multi point inspection as well. On the paper work under brake condition it shows 3mms front 6mm rear. What does it this mean exactly?
Old Aug 2, 2012 | 09:13 PM
  #6802
lokkii32's Avatar
Varrstoen ES 2.2.2. offset
I've decided to go with those wheels after all the searching. The question is I'm on a stock sport suspension. What offsets and tire size to use? And before you say it, I searched, but didnt get a conclusive answer.
Old Aug 2, 2012 | 09:45 PM
  #6803
thescreensavers's Avatar
Mr.202?
At 2mm you change the pads so you need to replace it soon. Depending on how many miles you have you should also change your rotors.
330 all around for rotors and pads+ install
Old Aug 2, 2012 | 09:57 PM
  #6804
dominate's Avatar
Unless you're going for stance and want a lot of poke, Varrstoens in general are not sedan friendly. If you want stance/poke then they're fine though. What offsets/tire sizes depends on what you want. In terms of stance, ride quality etc
Old Aug 3, 2012 | 08:27 AM
  #6805
bizz518's Avatar
Thanks for the info.
Old Aug 3, 2012 | 08:44 AM
  #6806
TunerMax's Avatar
G35
As screensaver said, 2mm is pretty much toast so you're getting close.
2mm is the "spec" during a safety inspeciton, 2mm or less and they must be replaced to pass safety. in actual fact, if htey're wearing evenly you can drive for a really long time with 2mm left before you HAVE to replace the pads.
I wouldn't go under 1mm though.
ALSO just want to note, most shops don't actually measure this, they just look at it and guess. Chances are you have mroe than 3mm there.
Old Aug 3, 2012 | 08:49 AM
  #6807
bizz518's Avatar
I guess this was the only down side of buying the car. Only had it 3 weeks but if it could pass inspection I doubt they would replace them under the 60 day 3000 mile warranty. I also notice vibration in the wheel when braking at higher speeds so I'm sure I'll need rotors too. Didn't notice this until a few days ago.
Old Aug 3, 2012 | 10:03 AM
  #6808
linedr89's Avatar
anyone know how to post pictures from your phone onto this website?
Old Aug 3, 2012 | 01:02 PM
  #6809
WhipWhitaker's Avatar
Thinking of buying a code reader/scanner
what do some of you guys use or recommend I look into?
(Assuming they're not all incredibly similar)
Old Aug 3, 2012 | 01:24 PM
  #6810
NFSP G35's Avatar
? = 2B || !2B
What kind of phone?
You have an Android smartphone? If so, there's a really good app for that
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
