Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Aug 18, 2012 | 12:26 AM
  #6946
dominate's Avatar
Are you dropped? Camber kit
Old Aug 18, 2012 | 09:35 AM
  #6947
WILLIE BEANS's Avatar
No im actually still stock height
no camber kit
Old Aug 18, 2012 | 12:58 PM
  #6948
The Stimulation's Avatar
Camber kit won't solve anything, that's just going to adjust camber. Your camber can be spot on, but if your toe is off, there goes your tire wear. Check to see if your bushings are worn out and if your toe is in spec. More than likely, it's one of those two.
Got a question myself, sorta. Couple weeks ago my brakes would squeal constantly, even when brakes weren't applied. I bought new brake pads since they seem to be quite low (in the rear, fronts seemed fine) and before I even had a chance to swap them out, no more sound. Ideas of what it could be? Still replace the pads? (If the rotors can be resurfaced I'll be doing that when putting on new pads).
Old Aug 18, 2012 | 01:51 PM
  #6949
K il do that thnx
Old Aug 18, 2012 | 02:07 PM
  #6950
Mr. Samster's Avatar
are the coupe muffler inlet pipe the same size as an 04 sedan inlet pipe? Its hard to find a sedan muffler. I want to get an aftermarket muffler but do not want to cut my OEM one in case i want to swap it back.
Old Aug 18, 2012 | 02:32 PM
  #6951
thescreensavers's Avatar
Mr.202?
^ You can run the Mid Pipe from teh coupe, but not the muffler without some modification in the sedan. That modification is cutting the spare tire well so that it can sit there.
You can get aftermarket mufflers that wont have to cut anything
Old Aug 18, 2012 | 02:40 PM
  #6952
it could be your pads werent seated properly and finally fit in the way they should be .
Make sure u use the grease to help prevent the squealing .
Old Aug 18, 2012 | 02:59 PM
  #6953
What I actually wanted to do was cut the coupe inlet pipe from the muffler and weld it onto the aftermarket muffler that I plan on buying. Ive been searching around from an 04 sedan muffler but couldn't find any, but found plenty of coupes. So i was just wondering if i can just use the coupe inlet pipes instead of the sedan one. I alrdy have a HR Y pipe and coupe mid pipe.
Old Aug 18, 2012 | 06:46 PM
  #6954
Mr.202?
Dont forget to look at the stickies! They are helpful too
Here is the post you want to look at
https://g35driver.com/forums/g35-sed...mpilation.html
Old Aug 19, 2012 | 12:31 AM
  #6955
CG4DR's Avatar
Originally Posted by IMA-G-RIDER
Question : what are common causes for inner tire wear on both my front tires on my 03 sedan?
lack of rotating tires.
Old Aug 19, 2012 | 12:48 AM
  #6956
Kingd's Avatar
So ive been given the opportunity to buy porsche calipers from a friend of mine. I was wondering if anyone has done this before and what problems may occur if i would try to run these on my 03 g sedan.
Old Aug 19, 2012 | 01:11 AM
  #6957
vapourinthesea's Avatar
Ok, I have another question. According to the owners manual, you have to use stock EVERYTHING (suspension, swaybars, brake pads and rotors, exhaust, EVERYTHING) on the G35X because if you don't the VDC won't work properly. I think that's a load of crud, but I thought I'd ask on here to make sure if that's true or not.
Old Aug 19, 2012 | 01:21 AM
  #6958
CG4DR's Avatar
special brackets and probably some other things. you can buy a factory 14'' complete kit for less than $1600 and it bolts right on.
There are plenty of modded X's on here. no one has issues if its done correctly and not half assed
Old Aug 19, 2012 | 10:35 PM
  #6959
Matzo Ball's Avatar
I have packing tape residue on my polished lips (just received my new set up). What is the best way to get it off w/o damaging the finish?
Old Aug 19, 2012 | 10:38 PM
  #6960
TORETTO's Avatar
using arcane magic
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
