Random Little Question Thread
Old Jan 22, 2013 | 09:27 AM
  #8401
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Originally Posted by Houston Coupe
so i traded my rims for some stock 17" rims but the tires the guy had on them were 215/50/17 is that a problem? they look kinda small and the inside of the door says 225/50/17 and 235/50/17 im planning on getting some new tires soon but will the 215s cause any problems i should be worried about?
Which oem 17's? You should be able to run a square setup on the OEM 17's. IIRC, the OEM 17's are 17x7+45 so that should allow you to run 225/50 or 225/55 on all four corners, the 55 series should be cheaper. If the wheels are staggered then you can do 17x7 with 225/55 and 17x7.5 with 235/55. Again it would be best to know which 17's to maximize traction, handling and tread life
Old Jan 22, 2013 | 10:39 AM
  #8402
DVG's Avatar
DVG
Originally Posted by Airic214
i seen yours b4 is there any one else running kurookie on a white sedan?
I used to have it, I kind of miss it. You can see pics here:
http://www.cardomain.com/ride/3845667/2003-infiniti-g/
I havent updated that page for a very long time, it really doesnt reflect how the car looks at all anymore.
Old Jan 22, 2013 | 03:32 PM
  #8403
Houston Coupe's Avatar
how do i know which ones they are? they have the 7 spokes and i do not think they are staggered. they just seem very small especially they rear wheels. what do you think is the largest tires a could get? would 245/50/17 work or should i stick with the 235?
Old Jan 22, 2013 | 03:43 PM
  #8404
ZS14's Avatar
Is this true?
https://g35driver.com/forums/lounge-...-anything.html
Old Jan 22, 2013 | 03:53 PM
  #8405
herrschaft's Avatar
Originally Posted by ZS14
If you look at the recent threads in the "lounge", you'll see a trend.
Old Jan 22, 2013 | 05:08 PM
  #8406
hnnguye2's Avatar
Hey, I have an automatic sedan with a little over 180k miles.
The problem is, sometimes when accelerating, there seems to be a drop when the car is switching into gear. Like a sudden silent thud, but i can feel it from time to time. Is this a problem with the transmission, or is this a problem that anyone is familiar with?
A second problem is when stopped abruptly, my car won't accelerate again until a few seconds later even when i push on the gas. Could this be my brakes. Another hint that the brakes are malfunctioning is that there are fluids that appears on the driver side front rims. Seems to be breaking fluid.
If anyone has these problems, lets get together and figure them out.
Old Jan 23, 2013 | 02:15 AM
  #8407
jdmGee's Avatar
2inch drop not enough
i just recently lowered my 04sedan with some tein lowerin springs only a 2 inch drop, i have 19x8.5 infront and 19x10.5 in back and the gap between the fender and tire is still too much. besides the obvious (coilovers) what else can i do to have more of a drop ? without spending alot more money.... thanks.
Old Jan 23, 2013 | 02:33 AM
  #8408
The Stimulation's Avatar
For the rear, springmount mod. For the front. Nothing.
Old Jan 23, 2013 | 03:27 AM
  #8409
JDMswagSerf's Avatar
do you guys know what this is?
THE BOTTOM cable with black handle.
it has a pic of a trunk opening but it has like no tension, it just hangs there, You can't pull it down.
I finally got my yellow fog bulbs. still need hid bulbs haha. & I plastidipped my wheels and bottom trim.
Old Jan 23, 2013 | 11:04 AM
  #8410
DVG's Avatar
DVG
It doesnt look like you got the self destruct option installed in your trunk.
In all honesty, I dont know. Kind of wondered about it myself but never bothered to ask.
Old Jan 23, 2013 | 11:35 AM
  #8411
lol.
yea I don't see any use for it, doesn't do anything. just gonna tuck it away in between the trunk and the cover.
Old Jan 23, 2013 | 11:49 AM
  #8412
Peoria35sedan's Avatar
Secondary trunk release, in case of power loss. It's should be velcroed to the trunk lining. Sounds like it's broken, close your trunk and reach in from the access panel between the rear seats to see if it works.
Old Jan 23, 2013 | 11:58 AM
  #8413
DVG's Avatar
DVG
Isn't that the purpose of the white glow in the dark one
Old Jan 23, 2013 | 12:12 PM
  #8414
Maybe it's tough to reach through the access panel ? That's the description straight out of the manual. Does the glow in the dark one do anything if there's no power, that could be the difference.
Old Jan 23, 2013 | 12:18 PM
  #8415
DVG's Avatar
DVG
Are you sure your reading the info for the right one? The glow in the dark one works with no power I'm pretty sure, its a cable. The cable on the black one is so small too, I think it would break if you gave it a yank
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
