Random Little Question Thread
#9796
No problem, thank you for the answer too.
#9797
2004doorG35x (12-14-2013)
#9798
#9799
So I went to get gas. After filling up I tried to start the car and everything went dead. All my lights, the navi, my dash, just all off. It was on when in the acc position, but died immediately when i switch to on. No crank or anything. So I switch the thing off and tried again and it started like normal. The rest of the day it worked as it should, but should I be worried?
#9800
#9801
#9802
Happened again today. Turns out it was just loose positive battery connection. I tighten up the nut and car started like normal again.
#9804
Having headlight issues. Started with passenger side low beam turning off minutes after driving. Replaced the ballest and nothing changed. Then I replaced both low beam bulbs. Passenger side now works fine, now the drivers side comes on then turns off. I have to flick them on and off a few times before it stays on. And sometimes during this process no headlights will come on then I have to wait a few seconds and repeat . Once they are on there are no issues. Had it at a shop before and was told the wireing and ballest were fine. What possibly could it be? A ground issue? 04 sedan.
2004doorG35x (12-18-2013)
#9806
#9810
Might be a stupid question (new to car modifications), but my ball joint on my SPC front camber kit is crooked. This can easily be put back into place by someone (such as my mechanic) with the proper tools right? Is this tool something almost all mechanic shops should have? Thanks
