Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Dec 8, 2014 | 05:32 PM
  #10201
ScraggleRock's Avatar
Originally Posted by dominate
Any slammed guys here run with their splash shield off? Mine is hanging off from the back and is scraping every small imperfection in the road, looks like a few of the mounting holes are torn. I'm gonna try and duct tape it or something but cannot afford a new one after getting my lower control arms replaced..
If the holes are just ripped just put some big washers on the bolt before installing.
Old Dec 8, 2014 | 05:34 PM
  #10202
Originally Posted by MrTBahgs
Anyone know the Low Tire Pressure warning threshold for when the light kicks on?
According to the inside of my door, the recommended pressure is 30PSI, I usually do 31, but either between a slow leak or colder temperatures, my light will turn on when I have a tire at like 28.5 or 29PSI.
That seems pretty extreme to have it engage so soon, I guess I am used to other cars where it turns on much lower like say 25psi where it would really show immediate need. I just get annoyed that it pops on and I wonder if its safe to drive to work before I can fill it and come to find out its only 1lb low.
Mine go off at exactly 34psi as the recommended psi on my car says 35psi. I run 50psi tho.
Old Dec 8, 2014 | 08:16 PM
  #10203
saywat?'s Avatar
u seriously run 50 psi in ur tires?
Old Dec 8, 2014 | 10:19 PM
  #10204
Fukc yeah. Yer supposed to run max if yer a man. Haha. The cars "suggestion" is for maximum mixture of comfort, gas mileage and safety. I don't care about the comfort part tho, so max psi is more safe and gives better mpg. Unless yer in situations where traction may be an issue, then I'd lower it. I'm in SoCal tho, so its sunny here all year.
Old Dec 8, 2014 | 11:51 PM
  #10205
MrTBahgs's Avatar
Hmm alright so maybe thats just their way of saying you are indeed low, mine wants 30 and alerts me at 29. Perhaps I should bump it up a bit to 32 or 33psi now, I thought it wasnt good to run it too high for more reasons than a worse ride, but never looked into it. Also, gas mileage can really increase a bit with firmer tires (more pressure)?
My ride comfort is fine, but I guess my tires are wearing odd or its just what they do when they get older because the road chatter is getting pretty insane lately especially for highway driving, certainly not quiet at all and if on the bluetooth phone the caller can hear the noise clearly (pretty sure thats the source of the noise for them). Perhaps running a bit more PSI will help the sound a bit, worth a try at least when I go to top it off. I believe I have Hankook Ventus V4 ES H105 tires, although I swear mine were W speed rating and not the H it claims the stock 17s would be (18s show W). Either way I might have to try a different tire when I go and make my purchase, I doubt the price will be friendly for a W rating (168mph) that I wont use anyway.
*edit* maybe the source is bad other sites show W, V, its all over the place, I'll have to see my tires in person again to check its rating
Old Dec 9, 2014 | 12:32 AM
  #10206
Yeah, imagine an under inflated basketball. It takes more energy to bounce, to roll the same distance, etc. cuz the less taught your material, the more energy it absorbs. The more you inflate them the more they can deflect. Same concept with tires. Absolutely nothing wrong with running full sidewall psi.
I wouldn't worry about the speed ratings. Anything sold for our cars, you'll most likely never come close to the speed rating.
Old Dec 9, 2014 | 01:18 AM
  #10207
saywat?'s Avatar
^ dude u really need to do some researching.
Old Dec 9, 2014 | 01:20 AM
  #10208
On what exactly?
Old Dec 9, 2014 | 01:22 AM
  #10209
saywat?'s Avatar
Over inflation
Old Dec 9, 2014 | 01:26 AM
  #10210
Over inflation
Ha! My grandpa owned a tire and wheel shop for high end European cars. I've been running max psi since I could drive. By all means prove me wrong.
Old Dec 9, 2014 | 01:41 AM
  #10211
saywat?'s Avatar
Well if that's how uve been rolling then keep on.
Old Dec 9, 2014 | 01:44 AM
  #10212
http://forums.anandtech.com/showthread.php?t=335140
This guy explains it great.
Old Dec 9, 2014 | 01:49 AM
  #10213
DahlieG35's Avatar
I apologize if I am being a so called "Noob", but I am new to this forum thing, and also my car. I just purchased a 2005 G35 Coupe and had just a few questions as I have never worked on or owned these cars. I was warned of the window problem and have experienced it now, twice in the past two weeks. Does anyone have a solution? The second question I wanted to get out there was specs on the amount of boost the stock internals can handle? I have heard that many of the internals are forged, but am curious as to more power options. Is there a supercharger that anybody knows of? I have seen pro-chargers and twin turbos... Thanks
Old Dec 9, 2014 | 01:57 AM
  #10214
thegreatkwijibo's Avatar
Search is a beautiful thing. most people use Vortech superchargers, but there are a few other brands. general consensus is that the stock engine is good for about 400hp. and you should be asking coupe guys about your windows, as you are currently in sedan land.
Old Dec 16, 2014 | 10:14 PM
  #10215
Justice06RR's Avatar
I have a small issue that recently came up.
The Odometer light that displays the Total mileage and Trip Meter went out yesterday. I can barely see it in the daytime, and can kinda see it at night. This is with the dash lights on max setting. Not a big deal because I can still read it, but a minor annoyance if you know what I mean.
Anyone have this issue? Btw I have a 05 Coupe 6MT with 117K miles if it matters.
Thanks in advance.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
