Putting the jack back in the trunk
Old Jul 27, 2010 | 11:28 PM
vchengap's Avatar
I'm sure this has been brought up before but I couldn't find it by searching.
How the f*** do I get the scissor jack back into its compartment in the trunk? I got it out just fine but after 30min of trying to put it back in I'm stumped.
I thought it went in with the top of the jack (the part that makes contact with the car when lifting) pointed towards the inside of the trunk. I could be wrong.
The Nissan engineer who designed this needs to be punched in the face.
Old Jul 27, 2010 | 11:41 PM
3truman's Avatar
i never had a problem with it, make sure its all the way closed, it goes up and at a slight angle and when it feels latched open it a bit and it will lock in place
Old Jul 27, 2010 | 11:56 PM
vchengap's Avatar
Thanks for the response, can you tell me if I'm putting the jack in correctly?
Old Jul 28, 2010 | 12:06 AM
3truman's Avatar
no you need to turn it counter clockwise, it needs to point up as if your using the jack, it goes in at an angle too.
Old Jul 28, 2010 | 04:24 PM
VEEG35.0's Avatar
i had the same prob i was about to go crazy cuz i couldnt put it back but ya it goes in facing up like u were using it just like 3truman said good luck
Old Jul 28, 2010 | 05:12 PM
DivZero's Avatar
Yep, have the jack as small as possible, angle into the sheet metal, then twist the screw to open the jack...thus holding it in place. And yeah, lol, it is a bad design.
Old Jul 28, 2010 | 05:53 PM
NjMatteSedan's Avatar
Old Jul 28, 2010 | 05:56 PM
GR6RR's Avatar
oh my...
Old Jul 28, 2010 | 09:57 PM
dumbg35x's Avatar
omg i have the same problem.. i just left it in the trunk... guess im goint to try this tomorrow.
Old Jul 28, 2010 | 10:28 PM
vchengap's Avatar
Thanks for the help guys - I got it back in. Took me less than a minute once I know what direction it was supposed to go in.
jsimonk
Dec 22, 2023 03:49 PM
Frostbite91
Aug 2, 2015 04:59 PM
DRG35R
Jul 31, 2015 10:23 AM
apintojr
Jul 23, 2015 10:52 AM
Jadenkid22
Jul 14, 2015 12:33 AM
