Which Front Upper Control Arm Will give me the most Camber?
Old Aug 8, 2010 | 05:58 PM
G2EnV's Avatar
help me out, im running a +14 offset 9 inch wide wheel up front.. the problem is that its poking out about half an inch, i have a kenetix upper control arm right now, but its maxed out and only gave me -1.0 i need another full degree to match my rears with fronts, thanks.
Old Aug 8, 2010 | 06:09 PM
Blue Dream's Avatar
I drove ttrank's car solo
SPC with the shims gives the most positive camber adjustment.
SPL the second most.
Old Aug 8, 2010 | 06:14 PM
G2EnV's Avatar
im looking to get more negative camber, right now im running -2.8 in the rear and -1.7 in the front i need another -1.0 up front, so i would need an arm that would go to -3.0 camber.
Old Aug 8, 2010 | 06:18 PM
SN00P's Avatar
CLUB MODERATOR
lower it MOARRRRRRRR and you will get some negative camber :-) SPC is the best to fix camber in the front but if you want - camber then just go with some front ichiba front A arms a lot cheaper then the SPC ... post a picture of your car ... what are your wheel offsets ??? i want to see why you are wanting more negative camber... are you aggressive ???
Old Aug 8, 2010 | 07:47 PM
G2EnV's Avatar
wheel specs Front - 9" +14 Rear - 10.5" +24, its lowered 1.5" all around. i dont want to go much lower because our roads are **** where im from.
Old Aug 8, 2010 | 07:51 PM
4drmadness's Avatar
pm donpisto
Old Aug 8, 2010 | 07:54 PM
SN00P's Avatar
CLUB MODERATOR
you fronts look fine .... whats wrong with them ... if your not lowered that much and want to stay within spec , stay with 350z specs and you will be ok .. are your rears rolled flat with that setup ?? IMO the whole car (camber) looks fine .. hell i wish my camber was like that im like -3.4 rear and -3 front lol if you go lower :-) you will have natural camber front and rear and that 1/2'' up front will go away .. yea roads here in florida sucks A$$ but its ok a little scrape never hurts anyone :-)
+1 ^^ pm levon he is the camber MASTER !!!
Old Aug 8, 2010 | 08:02 PM
G2EnV's Avatar
they stick out a little to far, they also rub on most bumbs, the rears are just rolled flat.. i dont have any issues in the rear with rubing. i want that wheel to be a little more tucked in the front and this should get rid of my rubbing issue.
Old Aug 8, 2010 | 08:05 PM
SN00P's Avatar
CLUB MODERATOR
well i have the same problem with rubbing in the front look into a fender finisher .. johnnyone just pinched his fronts and now running a +15 with no problem :-) im waiting for mine to come in so i can do it as well ... its was only like 53 bucks shipped from amazon .... then once you pinch the front and can lower it a lot more and wont rub .. hope that helps ..
Amazon Amazon
Old Aug 8, 2010 | 08:16 PM
G2EnV's Avatar
well i have that eastwood rolller tool, wouldnt that work? i think im gonna try either the ICHIBA control arms or spc ones.
Old Aug 8, 2010 | 08:19 PM
SN00P's Avatar
CLUB MODERATOR
yea the eastwood roller will do the same thing :-) take out the top screw and clip from the inside of the fender and roll from the left screw to the next right screw and wal la no more rubbing .. you can also flare it just a tad as well .. up to
Old Aug 9, 2010 | 06:27 AM
Blue Dream's Avatar
How about some side view shots?
And I'd suggest losing the brembo sticker on your sidemarker but that's just my opinion.
Old Aug 9, 2010 | 06:36 AM
4DGS's Avatar
You had better be sponsored by brembo...
Old Aug 9, 2010 | 11:17 AM
The Stimulation's Avatar
SPC's will give you the adjustment you need as will 350 Evo upper A arms. I use Cusco and had them modified to give me even more camber adjustment. Without the modification I got -4.1 camber and with the modification I got -4.7, but I can squeeze it out to -5 if I really wanted to.
If you're interested, here's what I did to get the additional camber. Not sure if this can be done with your Kinetix, but if so it will save you some money, just labor costs.
How pretty much everyone's upper A arms look
In progress modification
Ahhh....nice. Another 0.6 degrees of camber achieved.
Before upper A arms installed
After upper A arms installed
Basically I had the inner part shaved off and then had the plate flipped.
Old Aug 9, 2010 | 11:47 AM
Konsole's Avatar
I have a set of SPC front camber arms and shims for sale. I haven't posted in the marketplace yet. I never used the shims so all that stuff is new in the bag. The arms worked perfectly on my X, but I went back to stock so I took them off.
They are in great shape. PM me if interested. (I also have some Eibach pro-kit springs and a full set of struts/shocks available. I swapped out the struts because I figured they would be in bad shape, but I guess 42k miles isn't enough to mess them up... so they are used but in great shape.)
