e fan mod
Old Aug 28, 2010 | 07:43 AM
lowblocks's Avatar
e fan mod
hey peoples i need help is there any other efan out there besides flex-a-lite 220 i can use to do the conversion because this fan is very hard to find for a decent price and a lot of online stores don't carry this fan anymore.if there any on here that willing to part with there flex a lite i will buy it right away thanks
Old Aug 28, 2010 | 09:59 PM
NFSP G35's Avatar
? = 2B || !2B
I'm honestly just thinking about grabbing something from pick-n-pull
Old Aug 28, 2010 | 11:22 PM
G35Papa's Avatar
This is the one I'll be getting when I do my efan conversion
http://www.summitracing.com/parts/FLX-420/
Replaces the discontinued flex-a-lite 220
Old Aug 28, 2010 | 11:27 PM
kennymo's Avatar
go to the pick and pull and find some ls1 fans. or even a taurus fan, or intrepid fan. they work great and very easy to hook up
Old Aug 28, 2010 | 11:29 PM
NFSP G35's Avatar
? = 2B || !2B
^Good point. The Trans-Am did have a crazy strong fan on it.
Old Aug 29, 2010 | 10:33 AM
Mustang5L5's Avatar
Lincoln mark 8 fans will pull a small child through the radiator. Very popular fan for e fan conversions.
I run one on my mustang with a variable speed fan controller. Estimates are about 4000-5000 cfm on high speed. Prob the highest pulling oem fan on the market. I bought mine from ford for 140 bucks brand new a while back. Unsure if the price is the same. Used from pick and pulls are $25 or so. They do pull 40a continuous and 80a on startup, so gotta use a 75a Bosch relay to activate with appropriate wiring size and slow-blow fuses
This is also a good variable speed comtroller many guys use
http://www.dccontrol.com/fancontrol.htm
Old Aug 29, 2010 | 12:45 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
i think i should mount those fans on my wheels then to cool my brakes
Old Aug 29, 2010 | 01:41 PM
Mustang5L5's Avatar
Lol with four of them your car might turn into a hovercraft!
Old Aug 29, 2010 | 01:51 PM
Tollboothwilley's Avatar
Look in the the MISHIMOTO fans. You could run 2 of them just like the Flex-a-lite. They are thin fans so they will keep room in the engine bay as well.
Flex-a-lite 420 are a better design - quieter due to the S design of the fan blades vs. the 220.
The key here is AMP ratings of the fans. You don't want them to constantly be drawing too much and have your fuses blow. You DO want to have as many CFM (cubic feet per minute) out of the fans as possible though.
Old Aug 29, 2010 | 01:55 PM
NFSP G35's Avatar
? = 2B || !2B
That's good to know. I'm all about pulling small children through radiators
Old Aug 31, 2010 | 02:19 AM
lowblocks's Avatar
thanks I'm gonna use the flex a lite 420 and wire it the most simple way I'm gonna use the aux fan wires and wire 1 for low and the other for high so the turn on and off by them self if any one knows a better way please share it idk why there is no how to for this
Old Aug 31, 2010 | 05:55 PM
Mustang5L5's Avatar
Search the net...there are plenty.
Depending on how much current the fan draws you are gone want to use relays instead of wiring direct through switches. A fan controller would be an even better option.
Charchar66
Dec 19, 2019 01:17 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
RWDguy4238
Sep 30, 2015 12:13 AM
