Car overheating when stopped but ok when driving
Old Sep 1, 2010 | 07:23 AM
35bills's Avatar
Get a flush done and get the thermostat pressure checked. I have one done every two years.
What was the temperature outside when you first noticed the problem? My temp gauge did the dame thing as yours this summer as I was stuck in heavy traffic with the AC going..it was around 36C( 100F) that day. I blasted the heater and the engine temp dropped back to normal.
I haven't seen my car do this before or since....I have the mechanical fan set up since my car is an early '03.
Old Sep 1, 2010 | 10:35 AM
OKStateG35's Avatar
Originally Posted by Mustang5L5
Does your e fan even work?
Turn the ac on and see if the fan comes on. Heating up at idle and cooling on the highway is a sign of poor airflow through the rad. Most common cause is a dead e fan.
If I remember correctly, infinti extended the warranty period on the fan. I forget the mileage though...letter is in my car.
Of course a coolant flush wouldn't hurt either.
This. Seems pretty obvious that it's a problem with air flow since everything is fine when the car is moving.
Old Sep 1, 2010 | 11:38 AM
thescreensavers's Avatar
Mr.202?
^ His fluid is also dark which means it needs changing asap, Its probably not transferring heat too well so when the air flow goes down the fluid is not dispacing enough heat. When he is driving and gets more air flow the fluids lack of displacing heat is nil with the amount of air coming in.
That could also be it
chinee
Jun 10, 2024 07:48 PM
yassy
Aug 3, 2015 12:24 AM
newg37
Jul 26, 2015 09:32 AM
