Radio/ AC problem
Old Sep 15, 2010 | 03:04 AM
Junkyardspecial's Avatar
Radio/ AC problem
I believe I may have a short in in my dash somewhere, occasionally my radio will shut off then pop back on randomly. Also, sometimes the radio will stay on but all lights on the dash will shut off, and the buttons will not work except from the wheel. When this happens the AC turns its self on and wont shut off. Has anyone heard of this happening before?
Old Sep 15, 2010 | 05:27 AM
Blue Dream's Avatar
I drove ttrank's car solo
Let me guess, your car is an 03-04? If you read more on this forum you will find this is one of the most talked about issues with those year models. The problem lies with a circuit board in the headunit that controls the radio and AC controls. Your temporary solution which has worked for some is to smack the side of the console where the radio is mounted (not kidding).
Long term solution is to replace the radio, most go with a double din set up. There are a couple of places that will repair your original unit, but the consensus seems to be that it will eventually fail again. Good luck with your quest and check the Audio/Video section to find an endless of possibilities on ideas for replacement.
Old Sep 15, 2010 | 11:21 AM
Wannabe6MT's Avatar
-MN G Crew-
^What he said.
Old Sep 15, 2010 | 11:41 AM
THanks, guys I Searched but couldnt find. I figured the head unit was fine but it maybe getting moisture in from the Florida humidity.
Old Sep 15, 2010 | 11:59 AM
azt108's Avatar
I have the same problem. So annoying. The aftermarket route is so expensive because of the cost of the mounting kit. Unbelievable.
Old Sep 15, 2010 | 03:16 PM
Im going to best buy today to pick my laptop up ill see how much they estimate me.
Old Sep 15, 2010 | 04:05 PM
azt108's Avatar
Best Buy doesn't carry the DD kit.
Old Sep 15, 2010 | 06:38 PM
Where can i find that at?
Old Sep 15, 2010 | 10:56 PM
NFSP G35's Avatar
? = 2B || !2B
Cheap double din is the Metra kit (99-7604)
Better solution is the double din parts from the Japanese version of our cars that are made by Nissan. (OEM quality)
For that last option, search JDM DD kit or JDM Double Din, and you should find plenty of information.
That is your problem though, mine does it every once in a while. I just keep hitting it until I finish my double din, in dash computer.
Old Sep 15, 2010 | 11:32 PM
Hitting it seemed to not fix much Thanks for the info though!
Old Sep 15, 2010 | 11:35 PM
NFSP G35's Avatar
? = 2B || !2B
Where did you hit it?
Best place I've found is on the passenger side, on the side of the unit.
Same 'tap' you use to get the v-lock to act right on an old Panasonic TV
Old Sep 16, 2010 | 01:30 AM
haha thats EXACTLY where, I actually seemed to be knocking it loose. Mine only acts up with humid weather, winter is coming hopefully I can hold off on this til May.
Old Sep 16, 2010 | 01:44 AM
NFSP G35's Avatar
? = 2B || !2B
^Hmm. I guess yours must be in the final stages of it's terminal illness
Old Sep 17, 2010 | 03:05 AM
Wellll if it dies, ill have an excuse for a new console
Old Sep 17, 2010 | 11:12 AM
azt108's Avatar
If I beat the **** out of my headunit. I get so frustrated with it and the lack of an economical solution. Anyway OP, hit it around where the cubby is above the cigarette lighter on the passenger side. I also noticed that if you open and close the top cubby (where some have the OEM nav) it works if you close it hard.
