Speedometer, abs, ses, vdc off light. Malfunctioning.
Old Sep 20, 2010 | 08:01 PM
asma123's Avatar
Angry Speedometer, abs, ses, vdc off light. Malfunctioning.
Alright so I finally had time to take it to a shop and have the car checked. These codes came using x-431 tool
5 codes
P0500 : veh speed sen circ
P1212 : tcs/circ
U1001 : can comm circuit
P1574 : ascd vhl SPd sen
P0507 : isc system
Car was recently in a front end accident on the passenger side.
Symptoms:
Speedometer not working (engine revs do work and lights all work but speed says 0 even while moving)
Abs, ses and vdc off light are all on
Any ideas?
Old Sep 20, 2010 | 09:21 PM
Mustang5L5's Avatar
Sounds to me like some wiring was damaged somewhere.....most likely in he crash area. I'd start looking for a damaged harness
Old Sep 20, 2010 | 10:26 PM
asma123's Avatar
Upon further research I found this thread for a 2k4 maxima. same codes and actually same issue.
http://forums.nicoclub.com/help-2004...m-t355545.html
In keeping the knowledge base going:
The cause of this problem was a dead short in the ABS control unit. The short was between the IPDM to ABS control unit. The red/black power feed was grounding out over bumps to the ABS actuator bracket.
Luckily it was not the ABS unit itself because that would have been a $1300 job.
Can anyone go more into dept with this? I honestly have no idea what he's talking about.
06g35
Feb 14, 2022 05:59 AM
Thebaws11
Jul 2, 2021 11:36 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
markbilo
Sep 30, 2015 01:33 AM
vamarris
Sep 26, 2015 12:56 PM
