problem with Brake install (broke bolt)
Old Oct 2, 2010 | 10:37 PM
commadanteb's Avatar
As I was reinstalling the caliper I broke one of the bolts off inside of the caliper.
I am going to see If I can have one of the guys at work drill it out. If that works can I just buy a new bolt from home depot or autozone? Or do I have to go to infiniti
If that doesn work I guess i am in for a new caliper.
Old Oct 2, 2010 | 10:43 PM
Neu Era's Avatar
infiniti/nissan should have the bolt. I remember i broke one doing brakes on an 02 civic. that thing was like $8. what a rip-off, just for a bolt!
Old Oct 2, 2010 | 10:49 PM
Mustang5L5's Avatar
If you know the specs, you can buy a new bolt. It's prob a grade 10.9 bolt (roughly equivalent to grade 8 SAE) , and those aren't common home depot. Might have to order from somewhere like mcmaster-Carr but by the time you pay shipping, might as well go to Infiniti/Nissan and get one.
Dealership bolts are of better quality than parts store bolts though. They are usually held to tighter standards for fasterers used on automobiles while parts store bolts don't need to meet.
Old Oct 2, 2010 | 10:53 PM
thanks for the suggestions. I wouldnt mind paying the dealer prices, but they arent open on Sunday.
Old Oct 2, 2010 | 10:54 PM
Mustang5L5's Avatar
Well, you might have a tough time finding an equivalent bolt unless you go to real hardware stores that will carry metric 10.9 hardware...which isn't common
Old Oct 2, 2010 | 11:17 PM
jimNC's Avatar
Your best bet is to look for an old hardware store. Forget Lowe's/HD .. think smaller chain that has been in your town forever. Other than that, stealership.
Old Oct 3, 2010 | 01:55 AM
Will check a couple of local hardware stores tomorrow morning, like ace hardware. You were right, HD and lowes dont have anything close to this.
Hopefully the guys at work will be able to get the broken pin out tomorrow. ****, we make pins for air planes so I might even be able to find the right bolt...
Lesson learned, I need a torque wrench.....
Old Oct 3, 2010 | 02:29 AM
Just checked pepboys and autozone websites and it looks like they carry this type hardware. Autozone even has the caliper bracket, so if it comes to that I can just purchase the bracket for 34 and the pin for 8 bucks.
Old Oct 3, 2010 | 11:37 AM
nazc0's Avatar
2006 Vortech supercharged Sedan
i bought brake pads from autozone and they came with the bolts for some reason
Old Oct 3, 2010 | 03:30 PM
allright, we are all good now. Took the part to work and they were able to get the broken bolt out for me without damaging the grooves. Went to autozone and they had the bolts for $7.99. they said they were for the brembo brakes but the bolts were the exact same.
Thanks for everyones helps
chinee
Jun 10, 2024 07:48 PM
kinetek
Aug 3, 2015 04:25 PM
Crappyday
Jul 28, 2015 04:07 PM
newg37
Jul 26, 2015 09:32 AM
Lsantana757
Jul 20, 2015 09:08 AM
