Do these cracks on the belt require immediate attention?
Old Oct 9, 2010 | 09:38 PM
bigc's Avatar
Wings Nation
Originally Posted by WhosRich
How would you go about checking tension?
the FSM has some deflection test, but i just check by seeing how much i can twist the belt. in full disclosure though, my belt routing is no longer stock. anyway, if the belts squeak on cold start up they aren't tight enough.
Old Oct 9, 2010 | 09:45 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by bigc
doesn't look bad to me. fwiw, belts aren't that hard to change and you don't need a torque wrench.
remove undertray, break loose bolt on each tensioner pulley, loosen tensioners using socket & extension, swap belts, tighten up tensioners (check belt tightness as you go), tighten up the bolt on each tensioner pulley, reinstall undertray, drive over to your favorite watering hole or strip club
^This.
Those belts are fine. Cracks running along the length of the belt are what you should worry about, or if there are gaps missing, or cracks like that that run all the way across all the ribs.
My A/C belt broke recently (actually didn't break entirely apart, just one rib came off) so I replaced it, which required taking off both belts.
Wasn't hard at all. I've never done belts on a Nissan, didn't look up a DIY, and it still only took me about an hour, and that was doing an oil change too.
Old Oct 9, 2010 | 09:50 PM
Blue Dream's Avatar
I drove ttrank's car solo
Well aren't you special?
Old Oct 9, 2010 | 10:04 PM
CG4DR's Avatar
if you can twist it more than 90 degrees than its too lose.
basically when you think you have it tight enough, rev the car to between 3k-4k rpms and see if it squeaks. if not you are good. just recheck it about a week later due to the belt breaking in
Old Oct 9, 2010 | 10:05 PM
NFSP G35's Avatar
? = 2B || !2B
Old Oct 9, 2010 | 10:16 PM
CG4DR's Avatar
holy lazy eye!!
Old Oct 9, 2010 | 10:18 PM
NFSP G35's Avatar
? = 2B || !2B
^Yeah. I've used that same pic captioned "Speshul ketteh is just a little speshul" and that's the one I was looking for when Tim called me special.... but I found that one first and it made me so I used it instead
Old Oct 9, 2010 | 10:34 PM
mikeee2's Avatar
You got a torque wrench?
yes i have a torque wrench...
Old Oct 9, 2010 | 10:42 PM
WhosRich's Avatar
Guess thats a plus then, since everyone said you dont need one.
Old Oct 9, 2010 | 10:43 PM
mikeee2's Avatar
So what belts do you guys recommend? I heard good things about Gator...or go with OEM?
Old Oct 9, 2010 | 10:44 PM
NFSP G35's Avatar
? = 2B || !2B
^Gucci.
Old Oct 9, 2010 | 10:45 PM
CG4DR's Avatar
gucci?? gator are good belts.
Old Oct 9, 2010 | 11:16 PM
GOAT35's Avatar
cracks arnt bad but if you got chunks missing all over ur transmission needs to be looked at....I KNOW!
Old Oct 10, 2010 | 12:29 AM
Mustang5L5's Avatar
Nah, my belts have looked like that since 20K miles.
I have 67K miles now. I'll get to them soon anyway....maybe
Old Oct 10, 2010 | 12:35 AM
  #30
mikeee2's Avatar
So you have sporatic cracks all over? The other belt which the picture didn't come out clearly has small little cracks in a much bigger area but you can't really see it from the picture.
So our belts are serpentine or v? I don't know what the difference is. Also, if i am standing in front of the car with hood up. The left belt is = alternator/ps? The right belt is = ac?
So I guess I can wait a bit then. It's not squealing at all yet. Maybe I am just paranoid.
