? for people with BC coils on the g35x.
Old Oct 28, 2010 | 03:34 AM
jin22gt's Avatar
Ever since i had my BC Coilover installed on my 05 g35x, Ive been getting a squeak/rattle from the rear passenger side. Only happens everytime i go over a bump, it gets worse when its humid or rainy. Ive tried tighten everything and lubing all bushings, still no help.
Anybody else has this problem? is there a fix for this?
thanks
Old Oct 28, 2010 | 03:50 AM
socialconflicts's Avatar
^is it a rattle queak or a crack?
my front suspension cracks when the body flexes, i.e going into driveways or over bumps when the body of the vehicle is flexing in one directions (sideways)
the cracks come from the front and rear, infiniti tech told me my end links on the rear were bad. cant verify if this is true or not but i will replace them sometime.
i dont notice anything when in normal freeway/street driving
Old Oct 28, 2010 | 08:23 AM
mcaron's Avatar
did you happen to take off the front endlinks from the control arm? When i did mine i loosened those and when i went to go tighten it, i didnt jack up the control arm so it "sat" good in the hole, so every bump sounded like something was look. Kind of like metal on metal.
Again thos is for the front, just a little FYI
Old Oct 28, 2010 | 10:57 AM
TurTLe*'s Avatar
did you ever put on stock suspension to see if noise is gone?
I'm back in winter mode with stock suspension and i have a thump on driver side rear that wasn't present when i had the coilovers on, only on stock stuff over bumps or tight turns at low speeds, i think its the toe bolt but thats me.
Old Oct 28, 2010 | 11:55 AM
mcaron's Avatar
^Front or rear?
Old Oct 28, 2010 | 12:29 PM
b-lo's Avatar
I have a creak when I turn right now since I put on my bc coils. Seems to only happen on certain days. Some days its not there. It doesnt happen when I turn left.
Old Oct 28, 2010 | 02:11 PM
Pmpjuce06's Avatar
Damn thats weird. I have never had any of these issues! Good Luck with this!
Old Oct 28, 2010 | 03:53 PM
^knock on wood!
Old Oct 29, 2010 | 07:27 AM
TurTLe*'s Avatar
Originally Posted by mcaron
^Front or rear?
rear driver's hence why i think its my SPC toe bolt thing, thats part of the spring bucket.
Old Oct 29, 2010 | 10:55 AM
jarena2104's Avatar
i just slapped up my bc coilovers on my 07 g35x and its spring squeaking like crazy, sounds like its hitting the bump stops like crazy. i have no idea whats going on, prob gonna chuck this system soon. this is not luxurious in any way
Old Oct 29, 2010 | 12:23 PM
FlyingLumpia's Avatar
The hitting you are hearing is the a arm hitting the strut tower. Raise it up some. Even the rwd guys have this problem.
Old Apr 18, 2011 | 07:21 PM
MPG35fiend's Avatar
should i be worried???
im about to put my bc coils on my 04g35x with 18x8.5 all around... should i be worrying about any of these problems? are theses problems common for bc coils?
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
Rose M
Oct 12, 2015 10:00 AM
