ticking noise
Old Oct 30, 2010 | 05:44 PM
mkvl127's Avatar
ticking noise
i just started hearing a ticking noise coming from what i think is the drivers front wheel..i no its deffinatly the front..the click speeds up as i accelerate and slows down as i break..its so quiet that i can only hear it when coasting..ive had the passanger side bearing and hub assembly replaced under warrenty about 10,000 miles ago but that was more of a humming and not a click..ive checked both front tires for rocks or nails etc.anyone have an idea..and if it is a bearing i can just replace the bearing and not the hub assembly correct?..im no longer under warrenty 2005 G35x
Old Oct 30, 2010 | 06:17 PM
SkylineGTR2789's Avatar
Subscribed .. I have the same problem.
Old Oct 31, 2010 | 01:08 AM
Cabos G35 Coupe's Avatar
same here...
Old Oct 31, 2010 | 12:30 PM
t3_123's Avatar
subscribed sounds interesting
Old Oct 31, 2010 | 12:49 PM
jwolfpk's Avatar
i have the same problem..i believe there is a DIY on here i think its the axle that needs to be lubricated or something like that
Old Oct 31, 2010 | 12:54 PM
ilovez33's Avatar
im no expert but i am brown.....id suggest slowly backing away from the vehicle :-)
Old Oct 31, 2010 | 12:55 PM
SN00P's Avatar
CLUB MODERATOR
Get out of here ricky :-)
Old Oct 31, 2010 | 01:00 PM
ilovez33's Avatar
lol oh its a sedan thread.....haha fail.... Im Out!
Old Oct 31, 2010 | 01:24 PM
mkvl127's Avatar
if you are referring to the click when you first engage the car in gear and accelerate and it makes a click..its not that..that was only one click and thats it..i never had that problem this is more of a constant ticking as im moving..sounds like theres a nail in the tire but there isnt
Old Oct 31, 2010 | 01:42 PM
jwolfpk's Avatar
no im talking about a constant click that happens when driving you can hear it pretty well when just coasting at like 5mph..mine comes from my back right tire
Old Oct 31, 2010 | 01:43 PM
Mustang5L5's Avatar
Jack the front end up. Get both front tires in the air and give the wheels a spin. See if you can hear it that way.
Old Oct 31, 2010 | 11:24 PM
codeflux's Avatar
click from rear wheels sounds like either a nail in your tire, or burnt wheel bearings.
Old Nov 1, 2010 | 11:40 AM
Stryde's Avatar
Could be a rock stuck in your tire treads. I've had the same thing before, and it was due to a rock.
Old Nov 1, 2010 | 09:08 PM
mkvl127's Avatar
checked tires..its coming from the front driver side wheel
Old Nov 1, 2010 | 10:23 PM
jdubbyap's Avatar
I hear a click when I start moving in reverse. It only does it once. Is this a common thing or something that should raise caution?
