Difference between Stafe v2 and hakadori trunk?
Old Nov 2, 2010 | 10:32 AM
Azntran517's Avatar
I'm looking forward on making a couple of purchase with the group buy that going on. I just wanna know whats the difference them two trunks? Thanks.
Old Nov 2, 2010 | 10:39 AM
LordFappington's Avatar
At first I thought they were the same trunk, I believe its the size of the lip. The hd trunk lip is shorter? Correct me if Im wrong.
Old Nov 2, 2010 | 11:21 AM
MEXTEP's Avatar
Isn't it the other way around?...Strafe seems smaller.
Old Nov 2, 2010 | 11:38 AM
mt7rabbit's Avatar
Can someone post pics to see the difference?
Old Nov 2, 2010 | 11:45 AM
Bestswat's Avatar
strafe lip is smaller. It's really not that hard to notice.
Old Nov 2, 2010 | 11:56 AM
Bozookah's Avatar
strafe lip is shorter side to side and i think also shorter in height
Old Nov 2, 2010 | 12:25 PM
CandlestickPark's Avatar
ill Sedan
The HD trunk has a larger/taller lip, more "curvature" to the lip that the Strafe trunk. Just an FYI, the Strafe one also comes in a non-doggy door version. I've seen both in person, they both look great!
HD trunk
Strafe
Old Nov 2, 2010 | 12:35 PM
Strafe Automotive's Avatar
ask about fitment and body work needed to fit also.
Old Nov 2, 2010 | 01:48 PM
ill Sedan
Good point Law. I should have noted that the HD trunk I posted isn't the production version, its a modified OEM trunk. The production version takes some work in order to get it to fit properly and even then it won't 100% line up. From what I've seen the same is true for the Strafe trunk. See pics below, the reverse lights don't line up perfectly with the tail lights (sits a tad higher).
HD
Strafe
Old Nov 2, 2010 | 02:10 PM
AzWildcatG's Avatar
I was going to ask the same thing about the Nismo fronts from both vendors. Fitment, quality, ect..........
Old Nov 2, 2010 | 02:50 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
It is the same product from the same mold. As far as fitment and quality the front will need work to fit properly, also quality of the bumper could be better compared to others. Other than that you would be purhasing the same product from both of us. Only difference would be price and customer service.
Old Nov 2, 2010 | 04:10 PM
Stryde's Avatar
Marcus, aren't the Strafe trunk pics you posted just the version 1? I thought I saw some pics of the Strafe version 2 (deluxe) trunk, and it looked very similar to the HD trunk. I could be wrong, though!
Old Nov 2, 2010 | 04:19 PM
ill Sedan
Yes the pics I posted are of version 1. The lip is the same on the Strafe version 2 trunk. The difference is it doesn't have the doggy door as I pointed out in my first post.
Old Nov 2, 2010 | 04:32 PM
Stryde's Avatar
Right on. The missing doggy-door on the V2 Strafe was obvious. I just thought the V2 lip looked more like the HD lip...seemed a bit bigger than the V1 lip in the pictures I've seen. I didn't realize that the V1 and V2 lips were the same.
Old Nov 2, 2010 | 04:39 PM
ill Sedan
Strafe has V1 and V2 of their trunk, same size lip. They also sell the HD trunk under the name "Dlxe"
Strafe V2 Trunk (same as V1 trunk without doggy door)
https://g35driver.com/forums/exterio...e-arrived.html
"Dlxe" trunk that Strafe sells is the exact same as the HD trunk
https://g35driver.com/forums/exterio...an-trunks.html
