any AWD guys replaced their compression rod bushings?
Rating: Thread Rating: 10 votes, 5.00 average.
Old Nov 23, 2010 | 04:22 PM
TurTLe*'s Avatar
Originally Posted by hg35x
Here is the TSB - see Fig 12, pg 7 for the rusted one.
http://trueler.com/wp/wp-content/upl...ITB08-013a.pdf
I just had mine replaced and the dealer said the TSB did not apply to my car - wtf? Any way it was under a 3rd party aftermarket warranty which covered it, or I would be out $860. I paid $0.
TSB are not covered under any warranty. One your bumper to bumper is gone they dont give a rats behind. Recalled are covered not matter what.
TSB are just to let the techs know, hey there is a common problem this is how you fix it and since we ( nissan) are telling you how to fix it you can't diagnosis time for it. LOL $860... worst case is it takes me 2 hours and i buy the rods for $450 or so. Best case it takes me 2 hours and a trip to a shop and it cost me $50 for the bushings and $50 for the guy to press it. I just cant find a shop willing to press the bushings in. One place wanted $150 and a couple others didn't have presses.
Old Nov 23, 2010 | 06:10 PM
hg35x's Avatar
I totally agree with you about TSB's are not a recall - my warranty was through a 3rd party - the dealer showed 3 hours - maybe they "stuck it" to the warranty company. Isn't there a book for auto techs that show the labor time it takes to do a repair?
Old Jan 27, 2011 | 02:15 AM
brentcd's Avatar
Has anybody tried Autozone tool rental for a bushing press that would work for the bushing replacement job?
Old Jun 25, 2011 | 11:03 AM
jbro1's Avatar
So this appears to be the same tool you uncle used...Kent-Moore J-45813 Bushing Removal / Installer Tool. (also happens to be the same tool the Nissan specs for Bushing removal).
$269
Old Jun 27, 2011 | 11:47 AM
OKStateG35's Avatar
$269
Hmm, I wonder if this could be used to replace all of the bushings. If so, it would be worth buying and selling after you were finished. Specialty tools like this tend to hold their resale value pretty well.
Edit: Found the same tool on this site for a little cheaper.
http://tools.nissantechmate.com/Deta...?id=587&cid=12
Old Jun 27, 2011 | 12:40 PM
pulsar1's Avatar
Wouldn't be surprised if this was available as a rental tool.
Old Jun 28, 2011 | 10:03 AM
OKStateG35's Avatar
Looks like something very similar is available at AutoZone so you might be correct.
http://www.autozone.com/autozone/acc...questid=471481
Old Oct 11, 2011 | 01:08 AM
2006g35xsilver's Avatar
Anyone know if this includes the cup/remover shown below it (J-45813-1 and -2) or only the clamp itself? It looks like the universal clamp is sold for around that price by itself on other sites. I emailed the CS so hopefully they get back to me. I have a feeling this is an a la carte pricing. I'd much rather buy a tool and be able to install as many bushings as I destroy than buy 2 new control arms from NAPA, especially when I'm not exactly sure whether it's okay to replace the AWD iron ones with aftermarket aluminum replacements, and the oem iron ones are $350 (albeit w/ the ball joint).
As an aside, I have had that rattling/knocking problem exactly as has been described when running over small bumps the size of cobblestones or so . . . I have been looking under the car periodically thinking something was loose like the engine cover or something plastic in the wheel well-that's what it sounded like to me . . . I found myself having a big AHA! moment when I finally read about it here.
Old Oct 14, 2011 | 12:14 PM
I got a Kent Moore clamp (beefier one #41805) and the two specific bushing dies (45813-2 and 45813-2) from a seller on eBay. They look seriously beefy but from what I can tell looking at it (haven't actually replaced yet decided to hit with pb blaster until the weekend) if you just had a really big/heavy duty c-clamp and some heavy duty round metal pieces close to the correct size you could pop the bushing out as well.
Attached Thumbnails any AWD guys replaced their compression rod bushings?-img_3076_edited-1.jpg   any AWD guys replaced their compression rod bushings?-img_3077_edited-1.jpg   any AWD guys replaced their compression rod bushings?-img_3078_edited-1.jpg
Old Jun 18, 2012 | 12:31 PM
MJION's Avatar
Turtle did you ever replace your Compression rod bushings?
I have pretty much the exact noise as this post below..
https://g35driver.com/forums/brakes-...eo-inside.html
He changed out the bushing and still has the noise, I believe if your ball joint is shot too the only fix is to completely replace the whole compression rod... So I am going to take a closer look at my ball joints before I make the purchase...
Old Jun 19, 2012 | 10:23 AM
KingoftheRoad1's Avatar
I recently had the rods replaced. I did a lot of research before doing it. It's not worth it to replace just the bushings. The rods come with or without the ball joints. I replaced the ball joints also. So I would suggest you to do the same, replace the rods and the ball joints. Total cost about $600.
Old Jun 19, 2012 | 12:49 PM
MJION's Avatar
Thanks for the response..
I am going to try and replace the bushing first since my buddy is a Mechanic and will help me out. Figured I will try the $25 fix first, if that fails complete compression rod it is...
It sounds like the noise is isolated to one place so hopefully it is just the bushing..
Old Jun 19, 2012 | 12:51 PM
MJION's Avatar
I found that the ball joints are 1 piece and not available for individual sale and that they are connected to the compression rod. Not sure where you saw the rods without the ball joints..? Thanks
Old Jun 20, 2012 | 09:31 AM
Go to parts.com and you will see rods sold with/without ball joints. Parts.com sells OEM parts.
Old Jun 20, 2012 | 12:58 PM
  #30
Sonetlumiere87's Avatar
Dumb question, but I have an extended warranty from my dealership and it says bushings are covered under the warranty. With this creaking noise, would I be able to let my dealership's warranty handle it or would they try to say it's a wear and tear issue and leave it up to me to pay the full price for it?
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
