Issue with coupe seat swap
Old Dec 26, 2010 | 05:25 PM
TurTLe*'s Avatar
off-topic but since you have both seats and your swapping out. can you take pictures of the connectors under both seats for me.
Sounds like you have the exact same seat as me to start with. 05 memory/heated from a prem model.
Old Dec 26, 2010 | 10:43 PM
Tunerz_Store's Avatar
Re-use your connector from your OEM seat.
Old Dec 27, 2010 | 01:12 PM
Blue Dream's Avatar
I drove ttrank's car solo
turtle, I'm back to the grind at work and wondered if you'd like pictures of the sedan driver's and coupe passenger seat bottoms? Those are the 2 off the car atm and I don't know when I'm going to be able to get back to working on the project for a couple of weeks at least. I can tell you that the passenger plug for power to the seat is different on the coupe than the sedan.
HDET, I'll look into that and see if that might work.
Ashley, I would honestly need someone to help me with that as I am clueless about most things electrical.
Thanks all for your suggestions.
Old Dec 27, 2010 | 02:40 PM
TurTLe*'s Avatar
w/e you have time to do and label. I've been waiting for a local deal to pop up. Been holding back for 05-06 model. Good thing about stone is either stone or black can work for me.
from the other 2-3 threads i read. The pass side normally plugs right on up and you need about 3-4 wires to repin or splice on the drivers.
Both side heater connectors and airbag harnesses should be plug and play. Its just the power on either.
Does your sedan harness plug into the coupe seats? So all it needs is repinning or do you need to splice around it.
Old Dec 27, 2010 | 02:47 PM
TurTLe*'s Avatar
i asked a seller a while back to send me pictures of the connectors so i can figure out a possible splice points. This is what i have and i'm trying to make sense out of it.
I dont know which one is what. obviously yellows are SRS
there should be 6pin connector x 2 for the driver side of a sedan and just a 6 pin connector on the pass.
1 6pin for up/down recline/decline
1 6pin for tilt
Attached Thumbnails Issue with coupe seat swap-img_0767.jpg   Issue with coupe seat swap-img_0766.jpg
Old Dec 27, 2010 | 03:00 PM
erklep's Avatar
checked all fuses? mabye you blew a fuse somehow while installing the seats
Old Dec 27, 2010 | 03:20 PM
LightsOut's Avatar
SIETESG
in for future update
TurTLe*'s Avatar
if he blew a fuse, then that item would not work at all. broken fuse= no power going to X part. Its not fuse related.
I think the few sedans that have done the seat swap, none were memory seat cars to begin with... not sure positive on that tho.
Old Dec 27, 2010 | 04:17 PM
Mine was not memory seats and the seats I put in weren't either. My power connectors were different than the coupe seats also and it was a nightmare to get the forward/back sliding function to work as well. Ended up by passing something and using my control switches from the sedan seats.
Old Dec 27, 2010 | 04:55 PM
erklep's Avatar
i didnt read the whole thread. i wasnt aware that "x" part was operating
Old Dec 27, 2010 | 05:16 PM
Blue Dream's Avatar
I'm going to see if I can get out early in the morning to check out swapping the harnesses. Outside of that getting 05 coupe and sedan wiring manuals to figure out exactly what wire does what to be able to splice seems to be my next step. I just can't figure out what in the power harness caused the original non-starting issue. Something was cutting fuel or spark.
turtle, I'm sure you have seen this thread but if you haven't it shows some decent pictures. I'll get you what I can tomorrow and post them up.
https://g35driver.com/forums/g35-sed...ring-info.html
Old Dec 27, 2010 | 09:35 PM
G SEDAN's Avatar
i had memory seats on my sedan before going to a non-memory seat coupe seat.
I found a wiring diagram deep within this forum and followed the wiring to a T and it worked. Upon clicking blue dreams above link, I realized its the one I followed.
This wiring that I used was like this:
Black - Thick Black
White - Thick Red AND Thick Red with a white line
Grey with Blue Stripe - Thick Yellow green stripe
Light Green with Black Stripe - Thick Yellow
Old Dec 27, 2010 | 10:00 PM
Blue Dream's Avatar
Aaron, I think that's the consensus for the 03-04 seats but I think the 05-06 have different colored wires. I haven't been able to confirm that though. What years did you swap? IIRC you have an 04 sedan, what year coupe seats did you get?
I'd like Marcus to chime in as well since he has an 05. Marcus, where are ya?
Old Dec 27, 2010 | 10:07 PM
G SEDAN's Avatar
04 premium sedan => 03.5 non-premium coupe seats
Old Dec 27, 2010 | 10:37 PM
  #30
Blue Dream's Avatar
That's why the picture you followed worked. 05-06 are different i believe.
